3D bridge
art4u2000art4u2000 Posts: 1
I am having problems installing it to my photoshop cs6 64 bit, is it compatible, also i have two hard drives, my main drive has P Shop installed on it , and my second drive has daz installed on it, is taat a problem with installing 3d bridge.
    What happens when you try to install it? Are you installing with DAZ Install Manager or a stand-alone installer?
  • art4u2000art4u2000 Posts: 1
    i am using the daz manager but keeping a message about choose correct path i tried all sort of stuff and nothing works, i am running P Shop cs6, is it compatible with the bridge.... Totally comfused and new to this
    You have to enter the path to Photoshop in DIM (DAZ Install Manager), so that it knows where PS is installed to.
    Click on the 'Gear' icon at the top of the interface in DIM, select Applications, and enter the path to Photoshop in there.
    Make sure you set the application to Photoshop, and set the version correctly, in the dialogue box - a common mistake is to set the path but to leave the applicati9n set to DAZ Studio.
