Daz Canvas (Animation) Exr HDR output to Blackmagic Fusion.
I rendered my scene as exr with the canvas and checked the tone mapping in Affinity, so far all good.
But now I want to tone map the images in Blackmagic Fusion. But I can't find any nodes that give me the desired result.
Why can I render in DAZ 3D only in HDR? Can anyone help me how to make the Daz outputs usable in Blackmagic Fusion?
  • GordigGordig Posts: 10,168
    DS only outputs HDR files if you're rendering canvases. Without those, you can save as PNG or JPG, and even rendering with canvases outputs PNG/JPG for the primary canvas.
    Apart from that, I would imagine you can convert the HDRs to a more compatible format for use in Fusion using Affinity.
  • Ok i tweaked the color correctur node so many times until i realised that i had to use the lowest values for contrast and gain. I was tweaking the brightness the hole time. But yeh now it looks like my combined beauty pass.
    Here my node value. Be aware im not using the gamma, i just use the gammut node later on. Also after my main color correcture i added a second to make it brighter. And so on, will add maybe some more color correctures. ;D but for the default (exposure) correction i use this.
    339 x 801 - 44K
  • I already have the preview images as png. They are good for orientation when composing.
    The thing is, as an animation, I don't want to load and resave every single image in Affinity. That's what the EXR files are for. Now when I have EXR as output in Blender, the images are linear but I don't have to correctur to get the tonal values back in line. Blender uses Open Exr or Multy layered Exr. Now i just never worked with High Dynamic Images as output.
