Lara Croft/Tomb Raider clothing?
Toobis
Is there specific specific clothing you can purchase which is very close or identical to what Tomb Raider wears? I am looking hard here.
Anyone know if there is any? ty.
I have three that would suit you.
Complicated eve: http://www.daz3d.com/shop/complicated-eve/
Fawne V4: http://www.daz3d.com/shop/fawne-v4/
Gear punk V4: http://www.daz3d.com/shop/gear-punk-v4/
From memory, I think there's also a set at MostDigitalCreations.
http://www.most-digital-creations.com/adventurer_victoria_4.htm $4.
Unfortunately, the two for V3 & V4 by pretty3d are gone.
The "Project Lara" Freebie from a few years ago was very good, but no way to remember where I picked it up.
In Renderosity by Slide3D Time action clothes is incl the backpack.
Boots: High Tech Trekker Boots in Daz shop
Treadz also here in Daz shop
http://www.renderosity.com/mod/bcs/slide3d-time-action-clothes/84705
http://www.renderosity.com/mod/bcs/slide3d-boots-for-v4/81621
Is this it by any chance? http://www.renderosity.com/mod/freestuff/search.php?section_id=-1&query=LC+Gear&sort=relevancy&use_age=no&older;_age=&older_units=day&newer;_age=&newer_units=day&username=web_wizard
No, Project Lara was for Victoria 1 (and probably worked for V2). The one that is up now may be a re-work. I'll check it out.
Seems like there was a version for everybody (Including Irina for the original Stephanie) and they all just went away.
Maybe its time...
Seems like there was a version for everybody and they all just went away.
Maybe its time...
LOL! I got confused, this isn't for Project lara, but is a Lara V4 and A4 conforming outfit :)
Comparing the two side by side, I don't think the V4 version is a rework of the V1/V2.
UPDATE:
Looking at the textures, I was wrong. The V4 is an update.
UPDATE 2
OK, I've got the V4 Version loaded. It looks kike an automatic conversion of some kind.
The backpack (not the straps), equipment belt & equipment look pretty good, except the equipment belt is too loose.
The backpack straps look pretty bad but maybe retexturing can save them
The mesh of the shirt is either broken or it intersects V4's body. It still has the V1 Project Lara logo.
The shorts are too baggy. Maybe fixable but I'd sub something else instead.
Thanks for all these I have more than enough.
Much appreciated.
Those are clearly derived from Project Lara as they includes the .objs and textures for the weapons - and I was looking at the originals just a couple of weeks ago (the Tanfoglio pistol is one of the best modelled/textured Poser firearms I've come across - I use its textures for steel etc to replace textures that fall short on other weapons), but bizarrely they don't include the PP2s!
I also seem to recall the original Project Lara being built around hair and boots, neither of which are here.
If you are looking for some hair.
Hr-046 and Hr-045 in renderosity vendor ali
http://www.renderosity.com/mod/bcs/hr-046/72917
http://www.renderosity.com/mod/bcs/hr-045/72767
I was consolidating some of these items as well, for later reference. Here is a link: http://3doutlaw.com/home/?p=650
