Oh really? - Fun little blip
in Art Studio
I had fun making this, and honestly this is me. Everytime a customer tells me that they work for the government or that they know exactly how banks work since they've worked for banks for the past 30 years, this is my face on the other line,lol. But in all seriousness, how's it look?
The second image on here is just a witch doing witchy things, I thought it looked kind of neat.
Daz is doing something weird, it's not uploading certain images but it will upload others. Odd.
EDIT - I think there's a cap on how large an image can be, cause it will not upload the original image that I wanted, it keeps timing out and gives me an error message. Bummer.
Some tips:
Other than that, it looks good.
I've done a little research on what HDRI lighting is, but I think I need to do a lot more to understand how it effects an image. And the bloom filter, isn't that what makes it look "hazy"? If so, then that's what I've been looking for but had no idea what it was called or how to explain it properly in youtube. The SubD I've also heard of, but still not truly understanding how it effects a model. Based on what you're saying, it sounds like it effects the "roughness" of it in a way. Youtube will tell me what I need to know for sure. I'm gradually working on the cropping, and some of the other images that I've been working on are starting to look a little cleaner after it's been cropped in GIMP.
Otherwise, thank you!
An HDRI is just a big 360 degree photograph somebody snapped with a camera, including the lighting information from wherever they were standing. If you turn the gamma up too high, it's going to be covered in digital noise like your backdrop. It's not the lighting itself that's a problem, just the fact that the photo has too much gamma boosting.
The bloom filter will add a halo of light around bright objects. It has three settings: the radius, which controls how much the large the effect is; the threshold, which is how bright a light source needs to be before it gets bloom; and the brightness scale, which is how much brighter the bloom light will become.
SubD stands for subdivision surface. If you go into wireframe mode, you'll see your model is made of faces/quads. SubD will split each face into quadrants and do some math to flatten the angles between them. Basically, it breaks a face down into four little faces to create a smoother, less jagged surface. However, in addition to that, Daz's HD morphs only take effect on a subdivided mesh. You need to use SubD to see the fine HD details that come with Daz's figures.
