Is is possible to apply a decal on top of an existing model?
Boingo the Clown
I am converting a piece of construction equipment into a wacky custom tank.
I do not want to change the texture, but I do want to put a team emblem on the tank.
Is that possible?
If so, how do I do it?
In DAZ Studio? Probably the easiest way would be using the Layered Image Editor: http://docs.daz3d.com/doku.php/artzone/pub/software/lie/start
Is there somewhere else I can find the instructions?
Link works for me in Firefox
If the decal is (for example), a logo, you can add it to the Diffuse Strength channel in Daz Studio. You won't see anything in the viewport, but it will appear in the render.
mac
The link you gave was okay, but the actual links to the information on the page are all dead.
Since I could not access the information, I had to use a trick instead. I was lucky the surfaces I was putting the logo on were all flat, so I applied a transparent texture to a cube and duplicated it, then positioned the cubes and parented them to the object.
I would have used the layered image editor, but as noted already, the information was not accessable.
{{EDIT: The links lower on the page under "User Documentation" did work for me. I am looking at them now.
It was the three main links that were all dead links.}}
