Lip Sync?
Deke
Is lip syncing possible in the Daz 4.03 I downloaded? Or is that an extra plug in? I'm running the 64 bit version on an iMac.
I believe LipSync is 32 bit only. And I'm not absolutely certain it works at all on a Mac.
Thanks, any work arounds for Mac user who want to make characters talk?
Have you looked in the 32 bit version? You can safely install both 32 and 64 bit versions of DS on the same machine (as long as they are the same point version, for DS4).
Found the 32 bit zip in the original mac folder and installed it. The character I created in the 64 bit version seem to import just fine and the lip sync feature is here. So yet another new thing to learn. Are there any potential glitches in having both versions?
No, the only issue I had was that when a plugin is available in the 32 bit version but not the 64 bit version, if you open the 64 bit version the 32 bit version will lose the plugin's pane from its layout (because the layout is shared). On Windows you can run both at once, but starting a new scene will wipe the cached .tdl files and renders from the temp folder (which is shared) so that renders in the other version will fail. You do need to make sure that if you upgrade one to a new point version you upgrade the other too.
