Image movement issues
EpichallEpichall Posts: 54
Each time I reset a slider, whether it's to move an object or move a part of an object, or to rescale something etc etc, my image (set at Texture shaded) changes to a Wire Bounded Box. Not only is this pretty inconvenient when it comes to precise content placing, it also means that I can't see any of my animations correctly. All I see are various wire-bounded boxes going on and that's not use to me.
I've tried to adjust all of the controls that I can think of, but nothing seems to work.
Anyone any ideas of what I need to do?
I'm using DAZ 4.7 with Genesis characters on Windows 8.
TIA
  • Richard HaseltineRichard Haseltine Posts: 100,848
    In Tool Setting look at the During Manipulation settings, and change the first (DrawStyle) to Use Current (Off).
    edited February 2015
    If it only happens when you are moving something in the viewport, then you need to go to the Tools menu to fix it.
    Go to Window > Panes (Tabs) > Tool Settings, and in the window that pops up, find the heading During Manipulation, and change it to Use Current (Off). You may have changed it by accident at some point.
    EDIT:
    Richard beat me, I'm far too slow :)
    Post edited by JimmyC_2009 on
  • EpichallEpichall Posts: 54
    Never mind - you are both heroes ;-) Well done ;-)
