setting up a null prop?
MistaraMistara Posts: 38,675
is it possible to make it show in preview but not render?
is it possible to setup an individual instance to wire frame mode?
i'm finding it easier to drop cones and use 0 to zoom around with the camera
rather than saving camers positions and switching cameras.
i keep forgetting to hide cones :shut:
tested realsky shows in reflections :)
next test - volume clouds at ground level for dragon puffs. well in the morning. get so caught up forget it's sleepy time.
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,378
    Target helpers best if not wanting to show in render
    usefull for many things
    there is a visible in check box if you use props in general but of course that means you cannot see them in preview either
    edited February 2015
    where is the target helper? n/m i'm being lazy, can look up in manual
    thanks
    i wish it was in the lil primitives drop. or a right click.
    any way to lock the dolly ball? :lol: keeps turning into the flat thing :shut:
    aww, i crashed it. wanted to see what would happen if i enabled aura on Ambie. clicked the aura edit error message, now it's frozen.
    Post edited by Mistara on
    Top middle right, looks like a target you would shoot an arrow at, is the target helper.
    thanks.
    can't try it yet, my ca is still frozen. doesn't say not responding. could use a midnight snack break, give ca time to think
    edit- sees it. :)
