Questions about Displacement?
So I'm curious-is there a way to basically reverse the effect of the displacement tool? I am aware that it can pinch out my model, but I need a means to squish it-like the smooth tool, but much more potent...is this possible in Carrara Pro 8.5? Sorry if this has been asked before, but I'm tired of spending hours trimming models down with the smooth tool! Might as well grab myself a wooden drum and sand it down to a pencil with 400 grit haha
  • DartanbeckDartanbeck Posts: 21,650
    I think it does what you're asking... but I wish I knew what it is you're doing - so I could better understand how to answer. Have you tried using SubD Smoothing? But, yeah... I'm pretty sure that it has a smoothing brush. I'll try and have a look to be more sure - but it might be a while... I'm all out of computer time for now :(
    A little more specific information would be very helpful. Reference pictures or screen captures are also very useful if you can provide them.
  • edited December 1969
    Okay- So observe the included screenshot-I wish to push the model inwards, as indicated by the crudely drawn red line....Haha sorry if this seems vague, but your looking at a lowly Carrara noob haha...I can achieve this effect as I said through smoothing, but dang does it take forever! And by specifics, what would you guys be implying?
    1440 x 900 - 336K
    Maybe your level of smoothing is to high if it is so slow.
    As to pushing in a section, especially the area you've illustrated, perhaps soft select would be easier?
    Select a polygon, line or vertex and then on the right side of the screen, enable the Soft Select checkbox and adjust the slider to adjust the level of influence.
    BTW, using displacement painting works best on sub-divided models, but be careful not to go overboard.
    My example below illustrates a low poly, angular model that I first apply one level of subdivision. It looks pretty smooth with just one level and it does not bog the system down.
    The next images show the same smoothed model. I used Soft Select to make a large dent in the model.
    1198 x 675 - 250K
    1234 x 559 - 219K
    1172 x 665 - 209K
    1128 x 721 - 220K
  • DesertDudeDesertDude Posts: 1,238
    If you hold the Shift key while displacement painting it will "lower" the area you are painting.
