How to make characters deform due to collision with props or other characters?
newaltmlnewaltml Posts: 31
edited November 2021 in New Users
Is it possible to make a character deform due to collision with another character or prop?  For example: Characer A is poking character B with a finger and a stick.  The skin of character A should dimple in where the finger and stick make contact.  All the turtorials I have seen only indicate a way to make props deform due to contact with a character.  None of them indicate a way to make the shape of the character respond to an object or another character.
Post edited by newaltml on
  • NorthOf45NorthOf45 Posts: 5,550
    You could try Ghost Dynamics. It's not automatic, but should do what you want.
  • margravemargrave Posts: 1,822
    Natively, you could try hammering out a halfway decend solution with a smoothing modifier, push modifier, or dForce modifier on the figure, but frankly learning how to export to Blender and sculpt your own morphs is a better use of your time.
  • FSMCDesignsFSMCDesigns Posts: 12,779
    add a smoothing modifier to the figure and play with the collision and/or smoothing illiterations. it's not perfect, but unless you are willing to invest a ton of time learning a modeling app, it's the best solution inside DS.
  • SpaciousSpacious Posts: 481
    D-Former.  It's under the tools menu.  It's a bit tricky to get figured out and results may vary.
  • Try Mesh Grabber....
  • Thanks everyone!  I will try your suggestions.
  • charlescharles Posts: 849
    Mesh grabber is your easiest bet. It'll do what Ghost Dynamics does with much more accuracy except it's not HD.
