Question about the manipulator
![Sky Hndx](https://delorean.daz3d.com/forums/uploads/userpics/409/n3O60WQ1GIUEL.png)
I noticed that sometimes when working on a model and I select a point or edge the manipulator changes shape and appears a little distorted as if its been flattened a bit. But when I select a face it reverts back to its normal shape. So what I've been wondering is, erm, ...what have I done this time?
Some screen caps will help understand your problem better:)
Alrightie, I tried the little camera icon on the bottom right of Hexagon but the manipulator didn't appear in the cap so I hit PrtScn to get one. The resolution's a bit low but here's the manipulator on the same area of what I was working on. It appears this only occurs while in Manipulator Initialization Mode/Selection Mode. In World and Bbox mode the manipulator is it's normal shape. So it must be a normal function of the Selection Mode that I'm not aware of. :P
Sometimes the manipulator is even more distorted and flattened than whats in this cap while selecting a point or edge.
Yes, what you are seeing is normal - depending on your angle of view and which working plane you are using, the manipulator can appear to be perspective-foreshortened.
If this is a problem, you can rotate the 3D view to get a better angle, switch to camera mode, or define a user working plane.
See page 29 of the manual onward for a full explanation. The manual should be in the same folder as your installation, under docs.
I'm not normally a RTFM person, but in this case it would be better than me giving a long explanation :)
The FM in that folder was for second life sculpties and only went up to page 22. :blank:
...I'll google and find one somewhere
There should be four files in there - the Sculpties manual, the Readme, the Hexagon manual and keyboard shortcuts.
You can get it by following this link https://helpdaz.zendesk.com/entries/122228-Hexagon-User-s-Guide and scrolling down to Al Peterson's post. You can also get a handy users guide link at http://bio.attitude.free.fr/SOPHIE/HexagonTutorialUS.pdf
