carrara object's coordinate transfert in animation
![createo](https://delorean.daz3d.com/forums/uploads/userpics/205/nZ8VZ80C0PJL1.jpg)
Hello,
I want to tranfer the coordinates of an object to another being animation.
Is this possible by simply copy / paste or should we manually copy the coordinates x, y and z?
Can you help me please.
thank you very much
I'm not sure if I've clearly understood your question.
You have an object animated in Carrara? And you want another object to be given the same co-ordinates of the first object throughout the animation?
Perhaps you could make the second object a child of the first after giving the child object the same co-ordinates at the beginning of the animation.
The child object will follow the co-ordinates of the parent and you could make the parent invisible.
I don't know what would happen after un-parenting the child or after deleting the parent.
This is all I can think of because I'm not a Carrara expert. Perhaps others in the Carrara forum could help more.
