Clothing loading upside down? EDIT: SOLVED :)
Hi again everyone ^_^
I'm playing with the Mil Kids this time, and some nice freebie clothing I found for them at Faerie Dreams. It all loads and fits fine in DS 4.7, however when I try to bring the clothes into Carrara they are loading upside down underneath the figure!
If I do not select the figure when loading the clothes, they then load properly in the Zero position, but when I use Fit To... they then revert to the same upside down situation ^^;
I tried setting up the kids with their clothes in DS, then saving as a scene, then re-opening in Carrara. Same issue.
Is there a simple fix....??
Thanks in advance ^^;
EDIT -- UPDATE -- Same thing happens with the DAZ Hansel & Gretel outfit, which I just purchased to experiment with. So it's not the freebie. Most likely something to do with these being legacy figures :P
EDIT -- So here is a solution which is working nicely for me. I set up the figures and clothes in DS, then save them as a Scene Subset. I open this in Carrara and the figures are working fine. Why, I have no idea, but they do work :P Seems to me that the next step is to just save them to My Objects. Problem solved :)
EDIT -- Interesting. This method works with some items but not with others. One of these days I'll just have to get K4 I guess ^^;
This is probably a no brainer to more experienced Carrara users, but I'll leave this posted in case another newbie comes along :cheese:
