How to fix this clothes for Michael 5?
lord Adamlord Adam Posts: 125
Hello there!
This time I want to add some clothes for Michael 5 (they're oryginal designed for GENESIS 2 MALE - Sir_Worthington).
As you see on the picture below only shoes are corect with final pose. Besides I cannot apply smooth modifier:(...
What next step should I make then??
1927 x 1082 - 156K
  • Richard HaseltineRichard Haseltine Posts: 102,813
    Do you have the Genesis 2 Male Clone for Genesis http://www.daz3d.com/genesis-2-male-clone-for-genesis ? AutoFitting from Genesis 2 to Genesis is not supported by default.
  • LindseyLindsey Posts: 2,001
    This will address your fitting issues:
    On the Parameters tab for the pants, shirt, vest and boots:
    Enable Smoothing: ON
    Smoothing Iterations: 3
    Also, on the vest:
    Change Collision Item to: Sir_Shirt
    820 x 886 - 112K
  • lord Adamlord Adam Posts: 125
    Thanks a lot, I done all things that you said and everything looks fine now...
    Only one scrap of VEST (the red area)need to be modificate also by parametres tab??
    1481 x 881 - 164K
    edited March 2015
    I'm not seeing that on my end, but if that's poke thru from the shirt, you can bump up the Smoothing Iterations or Collision Iterations settings on the vest.
    Post edited by Lindsey on
    Before I make the final render I want to ad some grey beard and different hairs styles for MICHAEL 5.
    Is anyone of you know's where I should find a lot of medieval hair (beards/ moustache) styles for Michael 5??
    1923 x 1080 - 144K
  • cecilia.robinsoncecilia.robinson Posts: 2,208
    Try Short Beard for Genesis, Unshaven Bundle or Actual Facial Hair by Mindvision GDS.
  • kaotkblisskaotkbliss Posts: 2,914
    He's kinda looking like Christopher Lambert LOL
  • Scott LivingstonScott Livingston Posts: 4,344
    edited March 2015
    Any hair designed for Genesis should work fine on Michael 5. For facial hair I usually use Unshaven, but you'd have to adjust the colors on the Surfaces pane as I don't believe it comes with presets for gray hair. In addition to the options Cecilia mentioned, there's another product called Genesis Beard that you might consider.
    Edited to add: since you already have the G2M Clone for Genesis, you might take a look at the facial hair options for Genesis 2 Male as well.
    Post edited by Scott Livingston on
    There had to be (sir Robert of Huntingdon) 48-years old men... I have made face in FACESHOP 8, add one of many styles for Genesis Beard and long hair (still I've got not much for men hair styles in contrary to woman's hair).
    I don't know what to do more to make M5 look much more older than he is now??
    Maybe I should use something similar to AGED FOR M4/V4?
    1955 x 889 - 181K
    edited March 2015
    Try this: http://www.daz3d.com/aging-morphs-for-genesis :). For texturing: http://www.daz3d.com/skin-overlay-bundle.
    Post edited by cecilia.robinson on
    I already have ,,Aging Morphs For Genesis" (I add this CONTENT/FOLDERS to my main folder with all 3D content) on my disc, but I can't find this files anywhere... The SEARCH OPTION dosen't work. So now my 48-years old actor looks like young man at all...(as you see on the final render). I don't know how to use this ,,Skin Overlay Bundle" also:(
    1015 x 879 - 491K
    The aging morphs should automatically be added to the parameters settings once DIM installs the download.
    Select your genesis character and go to the parameters tab, search through the morph options until you see the aging ones, then move the slider back and forth until you have the desired effect.
    Ok, I just made some changes in parametres tab. Is my actor looks as 50-years old now?
    758 x 1084 - 100K
