exporting as an wavefront object without eyelashes
greetings!
hello everyone!
i need some help...i want to export a male form as an obj...it's all working ok but when i load the obj i can see the eyelashes..
can i get rid of them? i mean i want to have the effect of an statue,,,so the lashes should not appear...
can anyone help me with the settings, please?
thanx in advance
Eduardo
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,602
    If you turn down opacity/alpha on that surface in your import app it should hide them
    otherwise using the geometry editor tool you could select the eyelash surface and hide it under right click and then right click choose edit delete hidden vertices.
  • edited December 1969
    thank you so much for your kind answer! it worked!
    If you are making a statue you should just delete the Eyelash, Cornea, Tear and EyeReflection parts of the mesh.
