DzProperty.isSelected not work,can't find current selected Property
why the"DzProperty.isSelected"  not work,can't find current selected Property,alwasy retrun false!
  • SimonJMSimonJM Posts: 5,997
    An example of how you are using it might help those who know diagnose the issue
  • edited December 2021
    The code is very simple
    code removed
    I just don't know what is the Property selected status,I have tryed many times,just can't get a selected property.
    638 x 243 - 26K
    How about DzProperty.isSelected() - it's a method, not a value.
    Sorry, cross posted - where is getElementProperties coming from? It errors for me.
    I'm sorry,below is the full code.
    code removed due to lack of proper license complianance
  • That looks to be http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/properties/node_properties/start , in whichc ase please edit to include the required CC by Attribution info.
    The forum does support code blocks, between the button for inserting a picture link and the button for inserting a table.
    I'm not quite sure if it is possible to set the seelcted state in advance from the UI - restring the commented out test on the name and adding this as the conditional code
     {	oProperty.setSelected( true );}
    causes the property name to be printed so it is working, but I can't trigger it be clicking on a slider in regular or edit mode.
  • yes,it can be triggered by use oProperty.setSelected( true ),but can't be  trigger by click on UI,is it a bug?
  • I have removed the code from your post as you have not made it cinform to the license terms.
    I don't know if it is a bug or if we are simply not understanding what selection is meant to refer to. You could open a ticket to ask for clarification.
  • Ok, thanks for help!
