Invoking a command line argument via post-proces script
I found a denoiser the other day I really like. I want to automatically apply it to a render as soon as it's saved.
Is that possible? I don't see any obvious means of accomplishing this via App in a post-process script.
Looking to do:
"path_to_denoiser.exe" -i sAbsolutePath -o sAbsolutePath
  • MartirillaMartirilla Posts: 182
    edited December 2021
    The problem is likely to be found with the OS rather than the script. Windows for instance does not appear to permit passing command-line style arguments to an .exe file launched via a script. You might however instead invoke the .exe and pass it one of its own script types to do the required work. For instance, if the Denoiser is GMIC operating as a plugin for Photoshop, then in Python that would look like:
    import subprocesssubprocess.call([r'C:\Program Files\Adobe\Adobe Photoshop CC 2018\Photoshop.exe',r'C:\do_script.jsx'])
    Not sure what it looks like in DAZ Script though. But basically, just be aware that passing command line switches to an .exe may not be possible in a script running under Windows.
    Post edited by Martirilla on
  • OmnifluxOmniflux Posts: 383
    Combine Render Post-Process with DzProcess as referenced by Richard to implement this.
    Post edited by Omniflux on
