Old car-files on macOS Catalina (Solved)
Hi there
I managed to install Carrara 8.5 64 on Catalina
I can make new models - save them - and reopen them fine.
But my old save car files can not open
I get this error:
is there any hope for my old files?
Thanks Mic
65K
Post edited by michael-kristensen_e59faa8f72 on
  • HeadwaxHeadwax Posts: 9,967
    Gah ! You could try changing car file name to zip and unzipping them with 7zip then changing suffix back to car and trying to open it again. Long shot! Good luck!
  • RuudLRuudL Posts: 191
    edited January 2022
    Did you open the old file using the openfile dialog (via menu File>Open)? If so try opening the old file with a 'double-click' or with 'control-click' and then select Carrarra from the context-menu.
    An other option is to start Carrara and open a new scene. Now open a finder window and drag the old file into the new scene.
    With which version of Carrara were the old files saved?
    More information about Carrara on macOS Catalina can be found in following discussion thread: https://www.daz3d.com/forums/discussion/357626/macos-catalina ;
    Post edited by RuudL on
  • Thank you for your comments!!!
    Reading the tread of the link put me on to the browsertab which was reported to work.
    Go Carrara.app –> Show content
    Open Content/MacOS/Data/Plants/Leaves folder
    Put old car files here
    Close all folders
    Launch Carrara
    In brovsertab/Objects/Leaves you find your old files
    Drag one into a scene
    Save as...
    Now you can open that file by doubleclick in finder
    Mic
