An Odd Problem
CoryRose40CoryRose40 Posts: 25
edited March 2015 in New Users
I've run into an odd problem with the Star Character http://www.runtimedna.com/LLF_STAR/ I just started using her and was getting some real good results, then today this started to happen. I'm new to DAZ but this isn't happening with my other normal characters, V4, G2F, and Genesis all work just fine. Any one have any idea what could be causing the distortion? I am a Newbie, but so far none of my past problems seem to point to this one. This happens whenever I try and Pose the character with a preset or manually.
672 x 893 - 96K
672 x 893 - 57K
Post edited by CoryRose40 on
    edited March 2015
    Make sure that you are loading the correct version of the figure, the DS one for DS and not the Poser one.
    Oh and can you replace her bikini top or post an untextured version, as nudity is not allowed on the DAZ 3D forums. Thanks.
    Post edited by Chohole on
  • CoryRose40CoryRose40 Posts: 25
    I can remove the pic if you want, but the distorted version won't take a new top to hide the nudity. Sorry about that. And i used the version i always use to load the character.
    Are these the same poses you were using earlier, or are you posing b y hand?
    same pose, I added a top and skirt to keep the nudity down and turned the character a little to hide a bit more
    Is this in 4.7 or the 4.8 beta?
    4.7 version, and i just removed a recent update I did this morning and it still does the same thing.
  • Richard HaseltineRichard Haseltine Posts: 102,813
    What icon is next to the Star figure's entry in the Scene pane?
    3 boxes [one on top of two] right now
    After working on it for several hours I broke down and did a full reinstall of DAZ and the character and this has corrected the problem. I was trying to avoid doing this as I always end up losing a lot of things in the process. Thanks for the help, i know it was an odd one that no one seemed to have a clue about.
    972 x 893 - 487K
    If the boxes were separated by lines then you were using the Poser-format version, which would have loaded without the weight maps. DS/TriAx figures have the boxes not clearly separated.
