Greeble Building set
DMackey
I noticed a greeble set for building hallways, rooms, stairs and such.
I'm working on some post apocalyptic (heavy on the zombie side) images.
I have most of the park west and east models but would like to be able to
fill in areas not covered.
Any one working on something like that.
I'm not sure I understand the question. The Greeble sets are futuristic exterior city blocks, not interiors AFAIK. The West/East Park interiors should have enough to connect most interior setups, e.g. the West Park Basement includes "ground-level corridor section (for integration with the West Park corridors), a standalone staircase section, and a modular basement corridor section. The set also features a modular elevator shaft and elevator."
I understand that Greebles are basically set for SF applications.
maybe I didn't explain my self enough. What my thought was
Is a build a room or hall set up.
Say you wanted a hall with two doors on the left and one on the right and lets say the one on the right is partially hanging off its hinges.
It could have two texture settings one clean and on grungy.
My need is for interior settings for a zombie apocalyptic graphic novel I'm trying to produce.
There are enough props from different sites to litter a hallway.
I'm just learning blender so I haven't got to the place to create my own.
You can use the Geometry Editor in DS or the Grouping Tool in Poser, or an external modelling application, to break the West part model up into components and use those as your greebles - indeed, West part is already quite modular though you may to fiddle a bit with floors and ceilings.
Thanks Richard.
I'll look into it.
I think I must be misunderstanding the use of the word "greeble" (small g). Both the OP and Admin Richard seem to be using it more broadly than what I was thinking, Stonemason's "Greeble City Blocks". In any case, after reading the last few posts, another product comes to mind:
http://www.daz3d.com/room-creator-version-2
And there are the add-on products:
http://www.daz3d.com/room-creator-slums
http://www.daz3d.com/room-creator-industrial
Thanks Steve
