Please help on UndoStack usage
![function](https://delorean.daz3d.com/forums/uploads/userpics/483/nXTXXT5JX33PN.jpg)
Have fully read the DzUndoStack page, and found a lot of methods, but can not find any example, so don't know how to apply them in script.
Here is my exercise:
// This is a Undo test scriptvar aUndoLog = new Array (UndoStack)var sUndo= aUndoLog.toString () //var nUndoIndex = new aUndoLog.getCurrentIndex()//var nNumOfItems = new getNumItems(aUndoLog)aUndoLog.forEach (printEach)print (aUndoLog)print (sUndo)function printEach (sData, nIndex, aList){ print (nIndex, sData, aList) }
the result is sad:
Executing Script...
0 [object Object] [object Object]
[object Object]
[object Object]
It seems the varible aUndoLog was not correctly defined by just typing UndoStack, so it was returned a generic string representation [object Object]? Then how to define it?
Meanwhile, the UndoStack methods getCurrentIndex() and getNumItems() all got error message if executed:
TypeError: Result of expression 'aUndoLog.getCurrentIndex' [undefined] is not a constructor.
and
ReferenceError: Can't find variable: getNumItems
What are the correct usage for these methods?
I want to see some Undo and UndoStack examples, can anyone help? Thanks!
Redacted
UndoStack is itself a global variable, so in geernal you can access it directly, no need to assign it to a user-defined variable.
Got it. Thank you cridgit! and Thank you Richard!
