Update ! mcjWindowWall - Hyper-versatile Window-Wall prop ( tons o' stretch morphs )
mCasualmCasual Posts: 4,607
edited December 2015 in Freebies
over here at the bottom in the attachments section, click on the little blue down-arrow on the right
https://sites.google.com/site/mcasualsdazscripts5/mcjwindowwall2
HISTORY
December 25 2015 3h24am - Update: added 3 missing stretch morphs - made the default Scale 100% when resetting the prop
it will fit with the mcjWallDoor unit ( shown here )
and include a plethora of morphs and distinct materials
you'll be able to resize everything
i think i'll add something special, a morph that hides some parts of it by resizing those parts to nothing
1280 x 720 - 540K
1920 x 1080 - 549K
720 x 405 - 193K
720 x 405 - 210K
1280 x 720 - 752K
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    more the-making-of renders
    unfortunately i made the mcjWallDoor unit a bizarre default width
    but the mcjWindowWall will ab uh what's the word ... abut with it using the simple offset 300 cm
    1280 x 720 - 767K
  • edited December 1969
    This is going to be awesome! Thanks. I'll eagerly await its arrival.
    edited March 2015
    early Saturday i think
    then i get back to midi-music animation
    then kinect motion capture
    etc etc etc :)
    in the picture below:
    even if the wall and window is stretched in 100 ways,
    you'll be able to put patterned wallpaper or bricks or marble or wood
    fig 3 with a bump map
    fig 4 DigiDotz's marble was not lost on me ( oh my that pun hurts )
    1280 x 960 - 795K
    1280 x 960 - 673K
    640 x 480 - 91K
    640 x 480 - 103K
    edited March 2015
    fig 1 and 2
    excellent texturizingabilitating:
    each piece of wood will be UV mapped using the free script mcjBoxUV
    the name of the material for the piece of wood describes the unfolded size in centimeters ( will be in millimeters )
    jpg images with those dimensions ( 1024 pixels width or height ) will be bundled with the prop
    note : the prop, wall included is a modest 3000 faces!
    fig 3
    textures completed - actually the texture images now all have the same dpi
    so if you want, in your photoshop, you load a big 3kx3k texture of wood
    and you paste it without resizing to each one of the ... let me see ... 17 jpg images
    and your window looks like wood from the same tree
    1920 x 1440 - 456K
    1920 x 1440 - 824K
    1920 x 1440 - 1M
    856 x 561 - 88K
    1920 x 1440 - 1M
    This is going to be so handy. Thank you very much!
    edited March 2015
    i may make a 1-window version and a 3-window version also
    1920 x 1440 - 2M
    edited March 2015
    adding stretch morphs ...
    1920 x 1440 - 749K
    1920 x 1440 - 1M
    1920 x 1440 - 1M
    1920 x 1440 - 1M
    1740 x 666 - 563K
    edited March 2015
    it aaaalmost ready
    i have to solve the issues with the glass planes which i should not have split , i knew it , i knew it , i knew it ;)
    fig 2, solved (wrote a script that excludes vertices with certain materials from a morph )
    which means, i only have a few window-thicken morphs to add and it's all done !!!!!
    oops no, them glass edges cause problems elsewhere .... got to "sideline" them
    well actually, since it will rarely matter i'll add a band-aid morph for those 4 vertical glass edges
    1920 x 1080 - 907K
    800 x 586 - 261K
    1384 x 768 - 316K
    1920 x 1440 - 339K
    edited March 2015
    if you cant get the zip
    then use this direct link
    https://sites.google.com/site/mcasualsdazscripts5/mcjwalldoor/mcjWallDoor.zip?attredirects=0&d=1
    it's 3 megs, most of it in the jpeg wood textures
    the prop geometry itself is lightweight
    the morphs though numerous are probably not heavy on the cpu
  • scathascatha Posts: 756
    Cool, tnx, will be very useful
    edited March 2015
    i forgot to change the position of the origin of the windows
    i'll post a new version soon
    but for today you could load the prop
    and run this script
    which moves the origin ( and center of rotation ) of the two window props
    var node;
    node = Scene.findNode( "RightWindow" );
    if( node )
     node.setOrigin( 91.274, 131.493, 6.073 );
    node = Scene.findNode( "LeftWindow" );
    if( node )
     node.setOrigin( -91.281, 131.493, 6.073 );
    here's a direct link to that script moveMcjWindowWallWindowOrigins.dsa
    1280 x 720 - 597K
    edited March 2015
    for Wall crowns and baseboards you dont want to miss the big pack of mouldings
    found right here https://sites.google.com/site/mcasualsdazscripts3/straightmoldspack
    to help you re-adjust the wallpaper texture tiling after a wall stretching operation you can use the ABCD image posted below, you tweak UV tiling until you get square .... squares then you apply your real wallpaper
    if you want pixel-perfect wallpapers on stretched windowwalls
    then you can select the wall part of the prop
    run mcjBoxUV
    delete the wall
    load the wall that mcjBoxUV created at your request
    the wall is now excessively easy to texture
    in figure 4 you can see that the 3DViewport lies !!! when it comes time to show how UV tiling will be software-rendered
    ( at leas in DS3 )
    the wall on the left went through the mcjBoxUV re-UV-Mapping process and is therefore perfect :)
    http://www.daz3d.com/forums/discussion/36930/
    1280 x 720 - 728K
    1280 x 720 - 586K
    1280 x 720 - 611K
    600 x 600 - 31K
    1280 x 720 - 699K
  • ThatGuyThatGuy Posts: 794
    This is awesome. I was looking at this thread last night and wondered if the windows would open up or down, in fact, I wondered if it will open at all. Thanks for this!
    Thank you! Thank you! Thank you! This will be so useful for me. Your are a gem!
    Maybe I'm doing this wrong, but I think there might be some morphs missing specifically for the right side of the lower frame/trim?  I'm trying to shorten the bottom right side trims, but can't seem to find the morph slider for it.  I seem to only be able to do the left side.
    800 x 577 - 340K
    Post edited by ThatGuy on
    duplicate post removed by author
    yes they are missing
    i'll post the updated version today or tomorrow
    i'll also fix the thing that makes the prop disappear (scale 0 ) when you click on "delete keyframe" or "zero selected item"
    note that for this prop and others i add stretch morphs using my free script mcjAddStretchMorph and a simple cube
    * UPDATE * * UPDATE * * UPDATE * * UPDATE * * UPDATE * * UPDATE *
    thanks to ThatGuy for pointing this out
    mcjwindowwall2 was lacking 3 morphs used to stretch horizontal trimmings (planks) on the right side
    i also made the default Scale 100% for the 4 props
    Download and install ( or install-over ) the zip found at the bottom of the page here
    ( if it doent want to download it means you didnt click the famous little-down-arrow )
    note the prop was uploaded at 3h20 xmas morning THEN at 4:30
    the difference is that the 3 morphs cause a displacement of 10cm instead of 1cm .... this matches the behavior of the 45 other morphs
    960 x 1440 - 154K
    960 x 1440 - 141K
    Thanks very much for fixing this.  I really love this prop (as I do with all your stuff).
