Reflections
Hi all,
can someone tell me how I can remove fast all surface reflections? For examples for all walls in a room?
thanks in advance
  • HylasHylas Posts: 5,064
    If you´re rendering in IRAY you can either lower Glossy Layered Weight or increase Glossy Roughness.
  • SpaciousSpacious Posts: 481
    If that's still not enough, you can also crank up the "DIffuse Roughness".  Might also want to check to make sure "Top Coat" is not in use since that also reflects and has it's own settings for roughness.
