Daz Crashes While Canceling a 'New Window' Render?
A new -- and quite disruptive -- problem just cropped up.  I normally do an NVIDIA IRAY render with 'Render Target' set to "New Window' in the Render Settings tab -- so I can manually cancel the render, then save it, when image quality reaches a desired state.
Only today -- on multiple render attempts -- as soon as I select 'cancel' to stop the render, Daz immediately crashes, closing my rendered image window before I can save the image.  Heck of a way to lose about six hours of crunching on my graphics card.
A new Daz bug?  A lack of technique on my part?  Fixes or work-arounds?
Thank you!
  • Have you tried a newer/older driver for the graphics card?
  • RenderNoviceRenderNovice Posts: 56
    edited January 2022
    Thanks Richard,
    Yes -- had the problem both before -- and now after -- installing the latest studio driver from NVIDIA.  The crash is also happening if I just let Daz finish the render without cancelling: I get the error message saying Daz must close the instant it completes it's last iteration.  I would say the crash occurs on at least half of my render attempts now.
    This is a definite show-stopper.
    Post edited by RenderNovice on
  • Is it a crash straight to desktop or do you get the crash dialogue? I wonder if it might be a folder issue, related to writing the temp file or the thumbnail for the Render Album (which I suspect is done after stopping the render).
  • I get the crash dialogue every time.  Rendered files are saved to a dedicated folder on the C:/ SSD Drive.  The problem just surfaced seemingly 'out of the blue.'
  • frank0314frank0314 Posts: 14,049
    edited January 2022
    Have you updated Windows or GPU since the last time it worked properly?
    Edit: NM, should read better, lol. Have you tried to look at the log file to see if it is giving any helpful info?
    Post edited by frank0314 on
    In that case please save the report as a zip from the dialogue and attach it to a forum post.
    edited January 2022
    Attached -- lotsa' 'access violation' messages in the .xml file and 'conection refused' messages in the .txt file.
    There's definitely something strange going on, on top of scruffy having gone to bed...
    2022-01-18T20:48:48Z Failed to download output file "F:/DAZ/PROGRAM DATA/My Daz Connect Library\data\cloud\1_60183\props/make me itsy bitsy/materials/mm itsy bitsy sippy cup liquid 01.duf.part"
    Note the inconsistent use of "/" and "\"
    2022-01-26T09:20:38Z curl_easy_perform(https://hpclscruffy.daz3d.com/Server/ping?SID=zrKj194cgC7C4eOljjO_vVdp5oAfs7g6FZgDFX5LYB1sO5M3ruhC7A) failed: Couldn't resolve host name (scruffy asleep)
  • Thanks, PerttiA -- but I have no idea how these anomalies came to be, or how the word "scruffy" gets into a Daz URL.
    I've tried a System Restore -- and so far, the crashes seem to have gone away.  Still watching carefully.
