It does this when you create and select a NodeList (called NL). If you set it to None you get the environment back.
Thanks. But I don't think 'None' is the answer. None gives the result as the normal unCanvas render, or just a black background with any NL. What I want is a pic with the ball plus background, no cup, as same as other canvas tutorial shows. I want to use the cup to make a motion blur seperately, if everything in one render picture, or background is black, that is meaning less.
I almost believe it is a Bug, Canvas Beauty Bug in DAZ 4.16 Pro. Should I render 3 pictures to make a motion blur in PS? That is.... uh....
Ah, missunderstood the question then. But I can confirm with NL active the dome does not get rendered (DS 4.1.16.34 beta) - not sure about older versions though.
I almost believe it is a Bug, Canvas Beauty Bug in DAZ 4.16 Pro. Should I render 3 pictures to make a motion blur in PS? That is.... uh....![no no](https://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/thumbs_down.png)
