Way to copy things?
Toobis
When you create primitives and put them down is there a way to copy the exact same thing you just spend a while creating and making as many as you want of the same primitive with the same dimensions?
ty.
The Create primitive should remember your settings, and should remember sizes and divisions separately for each shape.
When creating props using Daz primitives, I find the best way to save them for reloading is to get rid of everything else, and save them as a scene. You can merge that scene (File>Merge) into whatever scene you are working on as many times as you want, but there is no built-in way to clone one item many times. Isn't there a 3rd party product called Send in the Clones? You can also export it as a Poser format prop and put it in your library.
