Mirror Problem - solved
Hello all a bit of a problem I'm working with.
I have two characters reflecting from a mirror. One reflects fine. The other one the hair only shows up partially in the reflection. Does anybody know how to fix this? Attached is an example. Thanks for your time
1400 x 788 - 658K
Post edited by 404nicg on
Is her reflection hidden behind the other person's head? Try moving her a bit to the right side, to see if this is an angle problem, or if she really is a vampire and has no reflection.
Though, looking at the image, the left person's hair doesn't seem to reflect properly, either. What is the ray depth you are using in you render settings?
The one on the left is who I'm speaking about. The figure on the right has a reflection but it doesn't show up because of this particular angle of this render. The hair doesn't show up. The ray depth is the default DAZ setting I'm not able to give you an exact number at the moment but I know I never changed it
Ahh i figured it out. Raytracing was turned off for certain MAT zones of the hair. Now I know, if I don't want something to show up in a reflection turn Raytracing OFF
