Using dynamic clothing in carrara?
Mosk the ScribeMosk the Scribe Posts: 888
Is there a way to get dynamic clothing ( like this set http://www.daz3d.com/dynamic-toga-and-skirt-bundle ) to work inside of Carrara?
Does it retain the dynamic function or simply work as regular conforming clothing?
Any settings I'd need to adjust?
Or will this only work inside of DAZ Studio?
Thanks
  • DUDUDUDU Posts: 1,945
    Thanks
    This kind of clothing is very easy to do yourself in Marvelous Designer and the Fenric's MDD Plugin for import into Carrara.
    Thanks
    It only works inside DAZ Studio with the Dynamic Clothing Plugin by Optitex, it is NOT conforming.
  • Mosk the ScribeMosk the Scribe Posts: 888
    ok - thanks for the clarification and for the possible workarounds
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,377
    edited April 2015
    The duf scene files of a calculated frozen DAZ studio cloth sim, so long as the frozen cloth is parented to the figure, will mostly import and render animated in C8.5 if kept simple namely figure and clothes
    you can add extra content in carrara
