Problems with DzJsonReader
kabexefkabexef Posts: 77
I try to use the DzJsonReader to parse a JSON-String. Therefore I wrote a jsonInterpreter which does nothing but output the called method and return true for each method.
const QString jsonString = "{ \"translations\": [{ \"detected_source_language\":\"EN\", \"text\":\"Hallo, Welt!\" }] }";QByteArray* byteArray = new QByteArray();byteArray->append(jsonString);QBuffer* buffer = new QBuffer(byteArray);outputWindow->clear();outputWindow->append(QString(*byteArray));buffer->open(QBuffer::ReadOnly);DzJsonReader* jsonReader = new DzJsonReader(buffer);KbxfJsonInterpreter* jsonInterpreter = new KbxfJsonInterpreter(outputWindow);DzError error = jsonReader->read(jsonInterpreter);outputWindow->append(QString("JSON-Reader result: %1").arg(getErrorMessage(error)));
Here is the code again, in case the source window is not well readable
The output I get is ...
{ "translations": [{ "detected_source_language":"EN", "text":"Hallo, Welt!" }] }
startObject(bool) = 1
skipObject
finishObject
JSON-Reader result: No error
... and I don't got any idea why i get no content (no addMember or addItem call) to the interpreter.
Any suggestions?
Post edited by kabexef on
  • vectorinusvectorinus Posts: 120
    edited February 2022
    Maybe you need to use functions  parse( )parseObject( );  parseArray( );  parseValue( const QString &memberName = QString::null )parseString( QString &str ) or parseFragment( const char *str )  to get the corresponding content?
    Post edited by vectorinus on
    Thanks for response but the mentioned methods are private in DzJsonReader so I can't use them explicitely.
  • DobitDobit Posts: 201
    It's been a while, but I still want to give a quick feedback. I tested the example and it seems to me that DzJsonReader needs multiline JSON. When I put newlines in the JSON example it works.
  • kabexefkabexef Posts: 77
    Thanks, I'll try it.
