Tight shirt made in blender inflates when transferred to figure
![kim.devylder](https://secure.gravatar.com/avatar/5a94157fe268008e07910fad18fa927e?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F5a94157fe268008e07910fad18fa927e_100.png)
Hi there,
I am trying to fit a shirt (mesh) that I made in Blender to my figure using the Transfer Utility.
Which ever setting I try the shirt will allways blow up a little. I've seen numerous tutorials where this does not happen but I can't figure out what's wrong.
I've been at this a long time. Hope someone can help.
Thanks!
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/91/7ae4836b40bdceae26881594015b97.png)
1601 x 1012 - 609K
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/15/eb77a4f2c7c3e1a1fd37f4e7c36625.png)
1602 x 1016 - 614K
Was is modeled for the default figure or for a morphed figure?
I made it from an exported Genesis 8.1 mesh but it's not the default one. It's a figure from a package I bought so I guess it's morphed.
The figure in the screenshots is what I exported to Blender to make the shirt from
If that is what you mean. Bit of a Noob here ;-)
General advice is always model towards the base mesh.
When using transfer utility, you can try change the donor from 'default' to 'current'. I have never actually used it, but my understanding is it should work.
You also need to expand the dialogue and select the Reverse Source Shape from Target option.
Wow, thanks a lot for your great help guys!
I had allready applied all transforms in Blender but thanks for the tip wolf659.
A combination of selecting "Item Shape" under "Source" and checking "Reverse Source Shape From Target" in the Transfer Utility seems to do the trick nicely.
Adding a screenshot of my settings for anyone facing a problem like this.
