Trouble with the mirror pose of i13.
ronkesronkes Posts: 28
edited December 1969 in Daz PA Commercial Products
Have trouble when using the mirror pose of i13 (Ethereal Wonder, ELUSIVE). The normal pose file works but the mirror (m) does not mirror the normal pose. If I save the mirror pose using Pose Builder the new file works. ???
  • Zev0Zev0 Posts: 7,098
    Pose Builder should be able to mirror whatever pose you have loaded.
  • ronkesronkes Posts: 28
    Yes it will.
    But why does the file that is label m not work with Pose Builder?
    edited April 2015
    Sometimes there is a conflict with Pose Builder when a pose is saved out as mirrored in a pose set. Just use the non-mirrored version of the pose and mirror that. I have no control over how other PA's save their pose information.
    Post edited by Zev0 on
    edited April 2015
    Thanks for the info.
    Just want you to know about this.
    I had trouble at first because the first file I tried using was an m type and it did not work but later found the that non m type worked.
    You can also use the m pose file on Gen 2 figure and then use Pose Builder to save that pose. The new file will then work with Pose Builder.
    I really like Pose Builder.
    Post edited by ronkes on
    Cool!! Glad I could help, and glad you like Pose Builder:)
