[Released] Props & Poses Converter from Genesis 2 to Genesis 3 [Commercial]
RiverSoft ArtRiverSoft Art Posts: 6,525
Easily use your Genesis 2 props, accessories, and poses with your Genesis 3 characters! Automatically convert almost your entire library of props, accessories, and poses using the Props & Poses Converter for Genesis 2 Female or the Props & Poses Converter for Genesis 2 Male scripts! The Props & Poses Converter scripts provide batch execution for automatically converting your Genesis 2 Female or Male props, accessories, and poses to Genesis 3 props, accessories, and poses in your library. Easily select the Genesis 2 props and poses in your library, select an output directory, and execute the script. Even better, icons and categories are copied from your Genesis 2 prop or pose to the new Genesis 3 prop or pose.
Your new Genesis 3 props, accessories, and poses are completely Smart Content aware! They will show up when you select a Genesis 3 Female or Genesis 3 Male. Plus, all of the materials shown in Smart Content for your Genesis 2 prop or accessory will show for your converted Genesis 3 prop or accessory.
Items without metadata can be converted but will not show up in Smart Content. They may also need to be converted using a Force Convert Item(s) button. Zero Poses are not converted.
  • Convert Genesis 2 props and accessories for use by Genesis 3 characters*
  • Convert Genesis 2 posed props (e.g., hand gripping a sword) to Genesis 3 posed props
  • Convert Genesis 2 poses to Genesis 3 poses
  • Convert Genesis 2 hierarchical poses to Genesis 3 hierarchical poses**
  • Convert swords, bows, glasses, jewelry, etc.
  • Convert accessories: hats, belts, glasses, jewelry, etc.
  • Copy icons from Genesis 2 presets to Genesis 3 presets for a professional look
  • Converted items are Smart Content enabled! All of the materials shown in Smart Content for your Genesis 2 props and accessories will show for your converted Genesis 3 props and accessories
  • Automatically convert almost your entire library of props, accessories, and poses with one operation!
Note that this product cannot do conversions between genders, i.e., it cannot convert Genesis 2 Female poses and props to Genesis 3 Male poses and props.
* The Props & Poses Converter scripts do not work with multi-part props (i.e., 2 daggers are loaded from the same preset) or with props/accessories with Genesis 2 bone rigging.
** Hierarchical poses require extra steps due to the props needing to be loaded. Some hierarchical poses cannot be saved correctly using a script and require a manual step.
1000 x 1300 - 356K
1000 x 1300 - 408K
1100 x 1300 - 412K
1641 x 1000 - 440K
1000 x 1300 - 545K
1000 x 1300 - 392K
1621 x 1000 - 357K
Post edited by RiverSoft Art on
