interlude ( meaning the midi scripts will resume after this ) - mcjStretchExtend - one-slider crouc
mCasualmCasual Posts: 4,607
edited April 2015 in Freebies
very soon
after i see if i can include automated-animation functions
a one-slider way of posing the legs
the jump animation was not really intended
but it shows 4 poses which could be dialed in simply by
selecting one foot
enabling/disabling the 3 check-boxes,
moving the slider
demonstration stills will follow and explain it all !
960 x 540 - 172K
1050 x 624 - 219K
1050 x 624 - 193K
640 x 480 - 768K
Post edited by mCasual on
    So, she's auditioning for the 20th anniversary Riverdance tour?
    Interesting looking script.
  • mCasualmCasual Posts: 4,607
    the impetus was
    all those times when we pose a figure and one of the feet goes just an annoying 1/4 inch through the floor
    so now, you select the foot, run the script, turn a slider a little and she pulls her foot up without bending her ankle
    the impetus was
    That 1/4 inch...oh I don't know how many times I just gave up and moved the blasted floor down a bit.
    edited April 2015
    animated demo right here right now
    800 x 600 - 65K
    800 x 600 - 83K
    480 x 270 - 1M
    edited April 2015
    in Figure 1 an animation made using 3 or 4 keyframed poses
    the poses were done in just 1 second using the upcoming mcjStretchExtend script
    but as you can see, due to curvy interpolation ( between keyframes ) the figure goes below floor level
    with the new ''animate range feature', the script will do the interpolation and we'll get rock-solid grounding
    1918 x 748 - 205K
    400 x 400 - 118K
    edited April 2015
    got lost a bit in making an A4 swimsuit
    but it's a good example of the use of mcjStretchExtend
    we want the support leg as stretched as possible
    and we want the other foot to stay resting on the ground
    so we're still at the point where
    the script works
    i just want to add animatability
    Figure3 ... the fixed pose! just using mcjStretch-Extend ( which i realized will definitely need some undo capabilities
    Fig. 4 i also will add the ability to move the hip forth/side/up and rotate it ... without losing the feet grounding pose !
    800 x 1000 - 502K
    800 x 1000 - 418K
    800 x 1000 - 484K
    800 x 1000 - 511K
    edited May 2015
    see that's the Hips Forth control
    it's probably similar to the standard Daz Studio 'pin'
    but precise and controlled i think
    the feet will be even more stable than shown here
    that's basically the first test results with moving hips !
    we had Amy standing and about to fall, now we can move her hips forth and make the pose credible
    768 x 524 - 691K
