Problem with environment in Daz/Blender Bridge.
![Honzo](https://secure.gravatar.com/avatar/6fe6f8afc62bcb572d974438f9d86ed8?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F6fe6f8afc62bcb572d974438f9d86ed8_100.png)
I'm having a problem moving an environment to Blender via the bridge. I was able to move this: Mountain Valley | Daz 3D no problem, although it bogs Blender much more than Daz. I cannot, however, move this: Moonshine's Diner | Daz 3D. It may have something to do with the fact that it condenses down to two items instead of one in the scene window. I tried ctrl-click click to join them, but when I use the bridge, there's a flicker and nothing seems to happen. Of course, it's hard to know what the bridge is doing most of the time. On the blender side, opening the tab and importing a prop/environment seems to reset the camera view, but that's all.
Any ideas how to fix this?
Also, is there a problem moving G3/8 figures with hair from other figures? It doesn't seem to work, although I've moved some other G8 figures with G8 hair.
Try diffeo.
I vouch for Diffeo !! Just make sure if you have emission surfaces , crank it up emission luminance in DAZ studio or give them specific colors so you can easilly indentified and boosting them Blender later
Daz blender bridge works fine for my figures. What does Diffeo do for props/environments that fbx export doesn't?
Well, for every scene I tried except one, it just works, without having to do much if anything. I mean I set up my lighting and cameras in blender, rather than trying to set it all up in DS then port all that over. So far, the only scene that has given me issues is Arch Cove scene. For some reason, base resolution, or high resolution import just hangs forever and I end up having to taskbar quit blender when I get tired of looking at the stupid animated circle thingie.
@Honzo material conversion, geografts, instances to name a few
Thanks! The first two would be very useful.
@Honzo Instances are very useful too. In the shop there are a number of scenes using instances that would be difficult or impossible to export without.
I'm not particularly focused on scenes, I prefer to use the assets to build my own scenes in blender
Plz tell me Why
