soon ( before June ) - mcjReach - Pose helper script
mCasualmCasual Posts: 4,607
edited May 2015 in Freebies
you select a target, for example a null node at the surface of a desk
you select a targeter, for example Amy's right index finger
you select the actor, for example Amy's abdomen joint
from the list of 6 transform properties, you select one, for example the Bend property
click the Go button
quicker tan the eye can see, mcjReach will try 30 bend angles for the Abdomen
( 3 degrees smaller to 3 degrees greater than the current bend angle )
it will set the Abdomen angle to the angle that minimizes the distance between the targeter and the target
you can then repeat the process with the hip, chest, shoulder, forearm etc etc until the target is reached
800 x 450 - 186K
280 x 310 - 348K
1080 x 1080 - 427K
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited May 2015
    There will be a special mode named "Assisted"
    The "reach" operation will involve a node named "The Pointer"
    this is somewhat similar to what mcjAutoLimb does but slightly more universal
    Example
    the Target is just above the bell-ringer's button
    the Targeter is just below Amy's index finger tip
    the Actor is the hand's Bend control
    the Pointer is the rShoulder - but we could have chosen the rCollar, the chest, the abdomen or the hip
    recall that the normal ( using the Go Button ) process is to
    test 30 Hand Bend angles and keep the Bend angle that minimizes
    the special "Assisted" process is to test 30 Hand Bend angles
    the difference between
    the distance from the Pointer ( shoulder ) and the targeter
    and
    why? because this way the length of the arm is ideal
    mcjReach then re-points ( hence the name Pointer ) at the target
    ( we say the arm, but in fact it's the imaginary line going from the shoulder to targeter )
    Fig. 2 : Amy's index finger tip Targeting Camera 3
    1600 x 900 - 735K
    1600 x 900 - 632K
  • WandWWandW Posts: 2,817
    This will be VERY useful! :coolsmirk:
    Thanx in advance!
  • jag11jag11 Posts: 885
    Thanx in advance!
    Like everything Casual does.
  • SkelchSkelch Posts: 275
    You give us so many amazing things, this will be up there among the most helpful. I also want to thank you in advance :)
  • KalisxKalisx Posts: 112
    Waiting for this useful script :-)
    Thank you for this new magical gift.
