Trouble deleting pose control keyframes
![Jarov27](https://secure.gravatar.com/avatar/d1b12b0802b6d6a1873fe54d24d3c547?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Fd1b12b0802b6d6a1873fe54d24d3c547_100.png)
I can't delete selected pose control keyframes in the timelime. I can delete any other keyframe just fine, but for whatever reason I can't with any pose controls. I discovered this when trying to delete pose controls for facial expressions, but it translates to any part of the body. It's really easy to recreate for me. I can go to a random frame, select a body part with pose controls like the pelvis. Alter a pose control, such as "knees up". Then select that pose control key in the timeline and hit either the delete selected keys button or right click and delete selected keys. The result is the same, nothing happens.
The actual controller is on the figure node, I believe, so try deleting its keys from there rather than from the pelvis.
Thanks, that worked. Didn't even realize there was a difference. Hopefully that changes in the future since it will probably confuse others as well.
Confused me! But Google and Richard's comment have fixed that. There is a ton of value to these forums. I don't post anything much, but I'm here a lot figuring out the issues. So thanks for that. :)
