How do i fix this morph/texture problem with this prop?
5200north5200north Posts: 249
How do I make this work...
here is a prop of a simple roller blind. i want a morph to raise or lower the blind. i took the blind part and reduced its size and the morph works great but the texure is distored. i guess i coulld use a texture that looks the same when you reside a prop but that's limits what i could do with the prop.
here's a render that explains the issue better than me.
1116 x 1116 - 791K
1116 x 1116 - 393K
  • Richard HaseltineRichard Haseltine Posts: 102,186
    You could guive the scaling portion its own surface, then adjust the vertical tiling to compensate.You could also reduce the issue by having more geometry for the scaling portion and squeezing it into the roller, then apply the scaling through successive morphs to that so that the visible portion was always fairly close to the aspect ratio of the mapping. The former would be easier to do, but it isn't simple to link material properties to a node property if you want to automate the process or animate lowering the blind.
  • IceCrMnIceCrMn Posts: 2,141
    Luckily that looks like a tiling shader was used so adjusting the number of horizontal and vertical tiles on the "Surfaces" pane should sort that one out quickly.
