Texture Paint Helper Loader install error
edited May 2015 in New Users
Hello,
When I try to install "Texture Paint Helper Loader(DS3_TexturePaintHelperLoader_1.0.0.0_Win64.exe)", the following error message pops up on the monitor.
"There has been an error. The installation path for DAZ studio could not be found... The application will exit now"
The path for DAZ studio application is the default(C:/program files/DAZ 3D/DAZStudio4) folder, but I assigned the contents path to D:/daz3d/My DAZ 3D Library.
Daz studio runs OK and TexPaintHelper was installed normally.
Plese let me know what to do.
Thank you in advance.
Post edited by 3rd-rate film director on
    edited May 2015
    On the Product Page for this item it says :
    Plugins for DAZ Studio 2.2 and 3.X now included!
    I don't think this is compatible with DS4 at all. You would need to drop a line to Support, unless anyone else here has an answer for you.
    The file name appears to be (DS3_TexturePaintHelperLoader_1.0.0.0_Win64.exe)”, What the installer is probably looking for is the DS3 install.
    Post edited by JimmyC_2009 on
  • edited December 1969
    Thanks for the reply.
    Actually, this app(Texture Paint Helper Loader) worked OK when I installed all the contents to the default paths.
    But there were not enough space for both applications and contents in my C drive as I purchase more and more contents day by day :) , so I had my DIM(Daz install manager) install the contents to non-default path.
    Though Daz studio( both 4.7 & 4.8 beta) works fine with that new configurations, the Texture Paint won't be installed.
    I am sorry, but I have no idea how the Loader program works. Moving the content shouldn't matter.
    Did you install the main Texture Helper program into the C drive, or to where your content is installed?
    You would need to install the helper to the same folder I would think, since the Loader depends on the main Texture Helper program being installed. Perhaps there is an .INI file that can be changed so that this can work, but that is as far as my thinking takes me.
    If nobody else can help, you will need to open a ticket with Support.
  • IceCrMnIceCrMn Posts: 2,149
    I don't have this product,,but most installers give you the option to change the install path.The installer should be run as the administrator and when it gets to the part where you can change the install path you can check that to make sure it's correct.Maybe that will help out with this error “There has been an error. The installation path for DAZ studio could not be found… The application will exit now” .
