Animation - Help from a beginner
patriciorojas7
Sorry, someone can help me.
I am a beginner and after download 4.8 DAZ 3D, I realize that in Posing / Shapping, beside Timeline, it does’n appear aniMate Lite. This is normal? What should I do to bring aniMate Lite?.
Thanks for the help and sorry for this basic question.
You should find the Animate pane in Window > Panes (Tabs) > Animate.
You can then drag it, and dock it at the bottom with the Timeline.
Thank you for your help. It seems to me that is a bigger problem since I already did what you advise me but "aniMate Lite" is not there.
Have a nice day.
Does it say 'DAZ Studio 4.8 Pro' in the title bar when you run DAZ Studio. If not, you need to enter the Serial Number that you got when you registered the software.
Had the same problem. Got studio 4.7 pro ,had animate 2 ( the free promo version ), next time I've opened daz, NO animate ( lite, animate or animate 2 ) some people said it's a daz bug and the way I fixed it was to buy animate 2 . That was the only solution I could make work ( before that I've done a clean reinstall of daz , disable / enable the animate 2 plug in , nothing worked ) . From what I've heard, after 30 days from instalation, daz should automaticly revert from animate 2 promo to animate lite ( it did for some people ) . Hope this helps.
Thank you for your help. After trying different things, I finally solved the problem by uninstalling and installing everything. I also took the opportunity to install the new version 4.8.
Greetings to all.
