Diffo error when exporting Daz to Blender?
![Preirin](https://delorean.daz3d.com/forums/uploads/userpics/856/nR5ZZI4PHQMDB.jpg)
Hello. I am new (and sure I have asked this before but still haven't received an answer) - when attempting to export from Daz to Blender with the Diffo tool, I encounter the error as displayed below. I have unisntalled and reinstalled Diffo three times to ensure I have installed correctly, and accordig to the tutorials, I have.
Has anyone else encountered this issue and have a fix? Cheers
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/66/0361968d637275cfcf0341b76ca53f.jpg)
567 x 466 - 40K
When you install a new version you have to replace both the blender and daz parts. Then export/import via dbz. If you use a old exporter with a new importer you may get issues.
Yeah - that's what I assumed, too, so I was very careful to reinstall step-by-step as if it were a new nstall every time.
I just can't tell f this is an issue on Daz's end or Blenders. I have tried xferring a basic 8.1 Femals with just hair, a tank top and shorts. No morphs, nothing really outrageous. Still having issues with a TON of missing assets. Starting to feel hopeless
It must be an issue with the daz root paths then. You have to save the daz root paths and load them back in blender. In my case I have the default content folder so nothing fancy, but some daz users may have a complicate set of root paths that needs to be imported.
https://diffeomorphic.blogspot.com/p/setting-things-up-version-16.html
