MRL Amara Braids posing not working on male.
GhostDogGhostDog Posts: 156
edited May 2022 in Daz Studio Discussion
I'm trying to use MRL Amara Braids  https://www.daz3d.com/mrl-amara-braids-for-genesis-3-and-8-female-s
on a male genesis 8.1 character but as soon as I fit the hair all the hair pose controls (except thickness) stop working.
Help! I love the hair and want to use it.
  • LeanaLeana Posts: 11,720
    If they use custom bones for posing then autofitting the hair will remove those, that's normal.
    I suggest parenting the hair to the head rather than autofitting: load G8M in default position, load hair but don't use "fit to", manually position / scale / morph the hair so that it fits the default figure, then parent it to the figure's head so that it follows the pose.
  • GhostDogGhostDog Posts: 156
    Thank you Leana!
  • GordigGordig Posts: 10,060
    You could also try the Scene Identification trick. Load the hair not fitted to the figure, select the hair, click the three-lined "hamburger" icon in the Scene pane, then go to (not at a computer, so I may not get this exactly right) Edit -> Scene Identification, change preferred base to G8.1M, then fit it to your male figure.
  • daradara Posts: 0
    Good morning from here. I tried to use the braid section option but it doesn't work. Have any tips for me?
    1366 x 768 - 234K
  • The braid option is a shader, not a material. You must select the Amara hair in the Scene tab and one of the three individual braids parts in the Surface tab.
