Looking for help on exporting a .blend file to .obj can't get materials to go over to .obj, any help
I made a simple plane for a backdrop in blender that has two materials on it, one green color and one pink. Two different materials, when I export to obj and import to daz I just get a white plane. Any tips?
  • Richard HaseltineRichard Haseltine Posts: 102,858
    You probably need to reset the colours in the Surfaces pane. With the prop selected they should be listed in the left hand column of the Editor tab, set the Diffuse colour for each on the right.
  • SzarkSzark Posts: 10,634
    Yep never worked Blender to DS, have to do it manually. It is weird as it works from Blender to Carrara. :)
    I never have a problem with simple colors...
    I saw the word material and assumed, my bad.
    I follow a simple rule...
    I assume that any imported (to Studio) geometry, will need to be manually textured within Studio itself, to get everything set up correctly. Even if it does come in with maps, they are probably loading from a directory that I don't want to be the final one, so they will need to be moved and reloaded at some point, so why not just do it from the beginning?
    I haven't been disappointed, yet... :lol:
