DAZ to C4D Bridge in R25
I just installed R25 and the most recent version of DAZ and the C4D Bridge. I can see and use it in DAZ, but it doesn't show up in Extensions in C$D. What is the name of the plug in so I can find it and see if it just got placed in the wrong folder.
Make sure tha that you have installed the C4D plugin. Please refer to these instructional resources:
Problem resolved.
Hi,
I cannot install the bridge in DAZ 4.20 for Mac. Whether it's installed through DAZ or Github it gives an error that it is not the right version. Any clues?
Thanks!
Hi, I cannot inslall the bridge in Daz 4.20 for Mac. It is not the right version it says...
Any clues, thanks!
Hi, I just posted a new Mac binary here: https://github.com/daz3d/DazToC4D/releases/tag/2022.1.8
- Download the libdzc4dbridge.dylib.v2022.1.8.19.zip, unzip it and then put the "libdzc4dbridge.dylib" file into your Daz Studio plugins folder, example: "/Applications/DAZ 3D/DAZStudio4 64-bit/plugins/"
- Please note that the file name for the plugin has changed to "lib
dzc4dbridge.dylib". So when you manually install it, you should look for any copies of the older file: "libdzbridge_c4d.dylib" and delete those.
If it still does not work, please send me the following information to help figure out what's going on:
