6000 x 3000 spherical maps from Anywhere in the ( watermarked non-commercial use ) Google Street Vie
mCasualmCasual Posts: 4,607
edited June 2015 in Freebies
>>>>>>>> https://sites.google.com/site/mcasualsdazscripts5/anywhereintheworld
This helps you convert the google street-view panoramas into images
which you can then apply to environment spheres
( it even works on plain Daz Studio Spheres )
The Google Street images are watermaked and most probably not usable for commercial purposes
NEW VERSION HTML5 Standalone !
Your browser needs to support HTML5 like Google Chrome on Windows does
Get mcjMosaicHTML5.html from the download/manual page
1 - copy&paste; your google-maps-streetview url in the textbox
2 - click the submit button
The panorama-mosaic will build up when it’s complete your browser is sent to the location of the panorama as a jpeg image
3 - Use your browser's "Save as", "Save image As" or "Copy"
The ( 1 day ) old version
a web page ( javascript ) to obtain the 91 Google Streetview image tiles
and a batch and imagemagick to do the montage
the result, a 6000 x 3000 pixels spherical/equirectangular image
which can then be applied to most environment spheres
including the plain Jane Daz-Studio primitive spheres
The ( last night ) old version, for Linux
this time the web page creates a batch file
which will use Linux's CURL utility to download the image tiles
there's also the
New Section - The Esmwy Python way for MACs and Linux
which uses Python scripts to download and assemble the mosaic on Macs and Linux
Free SkyBall Prop for Poser, Daz Studio and Carrara i guess
I posted a SkySphere prop which is compatible with those panorama images
http://www.daz3d.com/forums/discussion/57412/
https://sites.google.com/site/mcasualsdazscripts5/mcjskysphere
1280 x 720 - 210K
864 x 864 - 94K
864 x 864 - 146K
1280 x 720 - 144K
1280 x 720 - 176K
Post edited by mCasual on
«1
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,482
    this is so cool
  • mCasualmCasual Posts: 4,607
    edited June 2015
    just now i posted a SkySphere prop which is compatible with those panorama images
    1024 x 768 - 164K
    I'm getting some odd behavior...like no ability to save the page.
    It wants to save a copy of the script with the url I want from Google Maps in it, instead of a complete page with all the pics.
    edited June 2015
    in google chrome, once the mosaic of picture is displayed
    i click the google "Save Page As" menu
    and there's a "Webpage Complete" option
    which saves the whole thing including CBK images to disk
    maybe tomorrow i'll make a daz script version of it
    the javascript just extirpates the "pano-id" from the long GoogleMaps URL
    then it creates an html page with a 13x7 table of images
    http://cbk0.google.com/cbk?output=tile&panoid=DL1txH4VkTWOoChA6RYMeQ&zoom=4&x=1&y=3
    every few feet it takes photos that cover 360 degrees horizontally and almost 180 degrees vertically
    then they replace the missing ground using blurry patch from neighboring photos
    images from bicycle-mounted cameras and backpack-mounted-cameras are better in some ways because
    your Daz Studio camera is only slightly lower than that so there's less distorsion
    but you lose image sharpness of the ground
    1100 x 619 - 157K
    922 x 392 - 115K
    286 x 544 - 25K
    I just rightclicked save image myself.
    The google camera is an almost 360 spherical one I guess too, well getting there as it needs to point cloud map out the car its under :lol:
    in effect street view is a series of VR images along the roads.
    edited June 2015
    Yeah...for some reason, I have no options.
    I either get 1 image (one of the small 'tiles) or it saves mcjMosaic-3.html with no options for 'complete'. The number will increment, until I clear the history, then it will start over again.
    I finally got one to save, by opening the Chrome saved mcjMosaic-3.html in SeaMonkey, hitting Submit, again...and then in SeaMonkey it allowed me to save the Web page, complete...
    Except, it's saving the tiles in a different order, so the assembly script is not putting them together correctly...well, it is, but the order they are in is not making a nice image. And, no, I haven't determined a pattern that Seamonkey is saving the tiles in...it seems somewhat random.
    This is a snippet of the assembled output...
    544 x 583 - 527K
    Post edited by mjc1016 on
    mjc1016 said:
    saving images to disk
    maybe maybe maybe place the mcjMosaic.html elsewhere on your disk
    ( or even on a web site )
    tomorrow i'll see if i can make a Daz Script version that creates the plain-html page
    and i'll see if my google-site accepts to embed the javascript
    edited June 2015
    mjc1016 said:
    here's an online version of it http://mcasual.x10.mx/mcjMosaic.html
    other wild speculation : maybe your browser cache is too small or some security settings prevents the use of a cache
    maybe you attempt to save the page before Google had time to completely download/display it - that would make sense
    google would then save some images to disk from the cache and others from downloading them
    also, if you save the html twice using the same name, then the images from the two download will have identity crisis
    that's one reason why i saved it under the name JapanUenoPark.html and not mcjMosaic.html
    yep that's probably it,
    avoid re-using the same filename
    edited June 2015
    I'm on Linux and yes, I have read/write for the temp directory, the Chrome cache is in my home folder, and I'm working out of the home folder.
    I will give it a run as root, to see if it is a permissions problem.
    The compositing is working fine...except for the fact that the tiles aren't in any sane order, out of Seamonkey. On one run the pic in the upper left corner was cbk 46. Another, it was cbk 37. Two different locations....all runs of the same location, are the same numbering scheme. But I'm not sure if they are the same for each session...I haven't tried that one, yet.
    mjc1016 said:
    your browser probably starts many image downloads at once
    and as the files come in, it starts others
    each time assigning a different CBKNumber
    whereas google chrome on windows7 probably uses just 1 download thread
    and the order is well ordered
    edited June 2015
    mjc1016 said:
    hey i was on Oprah
    kidding kidding but i tested the system with the Opera browser , probably an Opera from last Christmas and it worked well
    i would think Opera exists for Linux
    you may also be able to use a Print-to-fax-as-tif
    or print to pdf
    or print to image
    i tried a print to Microsoft XPS file but it didnt work, it was promising i was "printing" it on D-Size "paper"
    edited June 2015
    mjc1016 said:
    Linux
    mcjMosaicLinuxCurler.html a solution for Linux
    For Linux Eyes Only
    Linux includes the curl tool which can be used to download files from the net
    the syntax is curl -o outputfilename URL
    so i include herein mcjMosaicLinuxCurler.html
    direct link to the zip file
    https://sites.google.com/site/mcasualsdazscripts5/anywhereintheworld/mcjMosaicLinuxCurler.zip?attredirects=0&d=1
    or the anywhereintheworld page
    an html page and javascript code
    which will print on-screen a batch file
    which can then be used to download the 91 images that form the mozaic
    so all you need is to be able to figure how to create a batch file and run it in Linux
    the output of mcjMosaicLinuxCurler.html looks like this ( see Figure 1 )
    ( note that i only tested this using Curl for windows and a .bat file )
    lets test a new location !!
    ok you pick one ?
    ok me ... hmm what song did i play yesterday
    i played Skyfall
    because i had the word SkyBall in mind
    this version https://www.youtube.com/watch?v=iZdBVjzIMSM
    soooo
    i will google-map-search for skyfall
    Skyfall Mobile Zip Line Hire Ltd
    the url .... i wont paste it here ! it's 2 ft long
    but i paste it in mcjMosaicLinuxCurler.html
    and faster than the eye can see ! i got my curler batch file
    it looks like this
    curl -o cbk "http://cbk0.google.com/cbk?output=tile&panoid=tXBV6Y5TOtFky8-7nS9P2Q&zoom=4&x=0&y=0";curl -o cbk(1) "http://cbk0.google.com/cbk?output=tile&panoid=tXBV6Y5TOtFky8-7nS9P2Q&zoom=4&x=1&y=0";curl -o cbk(2) "http://cbk0.google.com/cbk?output=tile&panoid=tXBV6Y5TOtFky8-7nS9P2Q&zoom=4&x=2&y=0";curl -o cbk(3) "http://cbk0.google.com/cbk?output=tile&panoid=tXBV6Y5TOtFky8-7nS9P2Q&zoom=4&x=3&y=0";curl -o cbk(4) "http://cbk0.google.com/cbk?output=tile&panoid=tXBV6Y5TOtFky8-7nS9P2Q&zoom=4&x=4&y=0";...curl -o cbk(12) "http://cbk0.google.com/cbk?output=tile&panoid=tXBV6Y5TOtFky8-7nS9P2Q&zoom=4&x=12&y=0";curl -o cbk(13) "http://cbk0.google.com/cbk?output=tile&panoid=tXBV6Y5TOtFky8-7nS9P2Q&zoom=4&x=0&y=1";curl -o cbk(14) "http://cbk0.google.com/cbk?output=tile&panoid=tXBV6Y5TOtFky8-7nS9P2Q&zoom=4&x=1&y=1";...curl -o cbk(89) "http://cbk0.google.com/cbk?output=tile&panoid=tXBV6Y5TOtFky8-7nS9P2Q&zoom=4&x=11&y=6";curl -o cbk(90) "http://cbk0.google.com/cbk?output=tile&panoid=tXBV6Y5TOtFky8-7nS9P2Q&zoom=4&x=12&y=6";
    i run this batch file in a folder containing curl.exe
    and a few seconds later i got my 91 cbk image tiles ( which by the way are in JPG format )
    i run mcjMontage.bat
    and bam i got my panorama
    my skyfall skyball
    Fig. 3/4 Who is Zumba? and shouldnt we ask Zumba before giving him/her a whirl?
    ( wikipedia: is a dance fitness program created by Colombian dancer and choreographer Alberto "Beto" Perez during the 1990s )
    512 x 1024 - 48K
    2000 x 1000 - 237K
    840 x 292 - 106K
  • EsemwyEsemwy Posts: 578
    Thanks for the script, Casual. I just created a render of a cartoon hippo on my front lawn, and it all works out great once I work around the windows-isms.
    To make my life easier, since I use OS X, I wrote a script to extract the filenames from the generated HTML file. This guarantees that I get them in the right order. Because I'm lazy, I found some code to create the mosaic right there in the script.
    The script is written in Python (included by default on OS X), and uses the Pillow module to create the mosaic. For those without Pillow installed, it falls back to ImageMagick.
    Perhaps someone will find it useful.
    python mcjMosaic.py path/to/html-file.html
    The output will be in a file named like "Montage 2015-06-09 at 11.00.34.png" in your current directory. If you'd prefer JPEG files, you can easily change the extension in the parameters section near the top of the script.
    #!/usr/bin/env python# Based on <a href="http://stackoverflow.com/questions/17555345/creating-a-montage-of-pictures-in-python">http://stackoverflow.com/questions/17555345/creating-a-montage-of-pictures-in-python</a>;from sys import path# needed for some package installs, harmless otherwisepath.append('/usr/local/lib/python2.7/site-packages')import osimport sysfrom time import strftimePIL_INSTALLED = Truetry:    from PIL import Image    from PIL import ImageDrawexcept:    PIL_INSTALLED = False    from subprocess import callimport re# parametersrow_size = 13margin = 0extension = '.png'def generate_montage(filenames):    images = [Image.open(filename) for filename in filenames]    width = 0    height = 0    i = 0    sum_x = max_y = 0     width = max(image.size[1]+margin for image in images)*row_size    height = sum(image.size[0]+margin for image in images)    montage = Image.new(mode='RGBA', size=(width, height), color=(0,0,0,0))    draw = ImageDraw.Draw(montage)    offset_x = offset_y = 0    i = 0    max_y = 0    max_x = 0    offset_x = 0    for image in images:        montage.paste(image, (offset_x, offset_y))        max_x = max(max_x, offset_x+image.size[0])        if i % row_size == row_size-1:             offset_y += max_y+margin            max_y = 0            offset_x = 0        else:            offset_x += image.size[0]+margin            max_y = max(max_y, image.size[1])        i += 1    if i % row_size:        offset_y += max_y    filename = strftime("Montage %Y-%m-%d at %H.%M.%S"+extension)    # montage = montage.crop((0, 0, max_x, offset_y))    montage.save(filename)def generate_montage_magick(filenames):    files = " ".join(filenames)    filename = strftime("Montage %Y-%m-%d at %H.%M.%S"+extension)    params = ['montage', '-geometry', '+0+0', '-tile', '13x7']+filenames+[filename]    print ' '.join(params)    call(params)def main(html):    pat = re.compile(r'src="([^"]+)"')    with open(html,'r') as fd:        text = fd.read()    files = [os.path.join(os.path.dirname(html),m) for m in re.findall(pat,text)]    try:        if len(files) > 1:            if PIL_INSTALLED:                generate_montage(files)            else:                generate_montage_magick(files)    except Exception as e:        print eif __name__ == '__main__':    main(sys.argv[1])
    Esemwy said:
    python
    come to think of it one could also do it in html5
    i'm reading here t hat converting the html5 canvas to image is as simple as
    var canvas = document.getElementById('example'),
        dataUrl = canvas.toDataURL(),
        imageFoo = document.createElement('img');
    imageFoo.src = dataUrl;
    // Style your image here
    imageFoo.style.width = '100px';
    imageFoo.style.height = '100px';
    // After you are done styling it, append it to the BODY element
    document.body.appendChild(imageFoo);
    edited June 2015
    Well, I just tested Esemwy's Python script and it works quite well...
    I'll give the curl method a try later, still trying to get my yard mowed before a thunderstorm blows in.
    1024 x 819 - 1M
    i have a fully HTML5/Javascript solution coming up! in the next minutes !
    as simple as
    1 - paste the google maps url in the box
    2 - click the submit button, wait 3 seconds
    3 - do a Save As
    edited June 2015
    HTML5 To The Rescue
    It's almost as if we were in 2015!
    this new version is fully contained in a web page
    ( javascript + HTML5 )
    Your browser needs to support HTML5 in a way similar to how Google Chrome on Windows 7 does
    or here's a direct link
    https://sites.google.com/site/mcasualsdazscripts5/anywhereintheworld/mcjMosaicHTML5.html?attredirects=0&d=1
    the panorama-mosaic will build up
    when it's complete your browser is unceremoniously sent to the location of the panorama-as-an-image
    it's a jpeg !
    which you can do "Save image as..." or "Copy"
    "Save Page As" may also work
    Figure 1
    Piazza San Pietro Rome
    the nice thing is, even if we cant use the images for commercial purposes,
    we can use it as a reference and 3d-build those sites
    Fig 2 seems to work fine with the google street images that are taken at some spots by ... contributors
    also in Rome --- labeled "Maan Servizi S.r.l. - Identity - See inside - Mar 2015"
    apparently this sphere is not watermarked to Google, maybe some have permissive licenses?
    Fig 3 spain
    1920 x 1080 - 298K
    2000 x 1000 - 264K
    2000 x 1000 - 386K
    2000 x 1000 - 318K
    edited June 2015
    Esemwy said:
    ... python code ...
    if it's ok with you i could copy your forum post with the python code
    and place it in a section called "The Python / MAC Way"
    in the https://sites.google.com/site/mcasualsdazscripts5/anywhereintheworld page
    edited June 2015
    Casual said:
    Esemwy said:
    ... python code ...
    That's fine with me. I have some minor updates.
    This version takes the Google Maps URL (in quotes to keep the shell from freaking out) and does all the work necessary to download the tiles and create a montage. It requires the Python 'requests' module.
    #!/usr/bin/env python# Based on <a href="http://stackoverflow.com/questions/17555345/creating-a-montage-of-pictures-in-python">http://stackoverflow.com/questions/17555345/creating-a-montage-of-pictures-in-python</a>;from sys import path# needed for some package installs, harmless otherwisepath.append('/usr/local/lib/python2.7/site-packages')import osimport sysfrom time import strftimeimport requestsfrom io import BytesIOPIL_INSTALLED = Truetry:    from PIL import Image    from PIL import ImageDrawexcept:    PIL_INSTALLED = False    from subprocess import callimport re# parametersrow_size = 13extension = '.png'url = 'http://cbk0.google.com/cbk'def generate_montage(files):    images = [ Image.open(file) for file in files ]    width = 0    height = 0    i = 0    sum_x = max_y = 0     width = max(image.size[1] for image in images)*row_size    height = max(image.size[0] for image in images)*len(images)/row_size    montage = Image.new(mode='RGBA', size=(width, height), color=(0,0,0,0))    draw = ImageDraw.Draw(montage)    offset_x = offset_y = 0    i = 0    max_y = 0    max_x = 0    offset_x = 0    for image in images:        montage.paste(image, (offset_x, offset_y))        max_x = max(max_x, offset_x+image.size[0])        if i % row_size == row_size-1:             offset_y += max_y            max_y = 0            offset_x = 0        else:            offset_x += image.size[0]            max_y = max(max_y, image.size[1])        i += 1    if i % row_size:        offset_y += max_y    filename = strftime("Montage %Y-%m-%d at %H.%M.%S"+extension)    # montage = montage.crop((0, 0, max_x, offset_y))    montage.save(filename)def generate_montage_magick(files):    filenames = []    for i, file in enumerate(files):        name = '/tmp/cbk_{:02d}.jpg'.format(i)        open(name,'w').write(file.read())        filenames.append(name)    filename = strftime("Montage %Y-%m-%d at %H.%M.%S"+extension)    params = ['montage', '-geometry', '+0+0', '-tile', '13x7']+filenames+[filename]    print ' '.join(params)    call(params)def extractPanoid( mapsLink ):    fields = mapsLink.split( "!" )    for f in fields:        if f.startswith('1s'):            return f[2:102]    return Nonedef downloadAll(mapsLink):    panoid = extractPanoid( mapsLink )    files = []    for y in xrange(0,7):        for x in xrange(0,13):            payload = {                'output' : 'tile',                'panoid' : panoid,                'zoom'   : 4,                'x'      : x,                'y'      : y            }            r = requests.get(url, params=payload)            files.append(BytesIO(r.content))    try:        if len(files) > 1:            if PIL_INSTALLED:                generate_montage(files)            else:                generate_montage_magick(files)    except Exception as e:        print e    def main(html):    pat = re.compile(r'src="([^"]+)"')    with open(html,'r') as fd:        text = fd.read()    files = [os.path.join(os.path.dirname(html),m) for m in re.findall(pat,text)]    try:        if len(files) > 1:            if PIL_INSTALLED:                generate_montage(files)            else:                generate_montage_magick(files)    except Exception as e:        print eif __name__ == '__main__':    downloadAll(sys.argv[1])
    Post edited by Esemwy on
    edited June 2015
    i copied the text from the forum and did a save-as-plain-text
    to create the two Python files
    so i guess i should or someone else :D should check if it didnt break the annoying Python indentation laws
    maybe the html source of the forum ...
    edited November 2015
    in case someone someday googles about HTML5 canvas-to-image
    here's the main HTML code of mcjMosaicHTML5.html
    well except for the dangerous codes the forum software removed
    var g_mosaic_canvas;var g_mosaic_context;var g_dimensionTile = 512;var theresultsarein = 0;function extractPanoid( mapsLink ){ var fields = mapsLink .split( &quot;!&quot; ) var count = fields.length for( var i = 0; i &lt; count; i++ ) {  var str = fields[ i ];  var prefix = str.substring(0, 2) ;  if( prefix == &quot;1s&quot; )  {   return( str.substring(2, 100) )  } } return( 0 );}function drawShape( ){ var nTilesX = 13; var nTilesY = 7; var panoid  = document.getElementById(&#39;panoid&#39;).value; panoid = extractPanoid( panoid ); var widthCanvas = nTilesX * g_dimensionTile ; var heightCanvas = nTilesY * g_dimensionTile ; g_mosaic_canvas = document.getElementById( &quot;mosaic_canvas&quot; ); g_mosaic_context = g_mosaic_canvas.getContext( &quot;2d&quot; ); for( var y = 0; y &lt; nTilesY; y++ ) {  for( var x = 0; x &lt; nTilesX ; x++)  {   var path = &#39;http://cbk0.google.com/cbk?output=tile&amp;panoid;=&#39; + panoid + &#39;&amp;zoom=4&amp;x=&#39; + x + &#39;&amp;y=&#39; + y;   var cat = new Image();   cat.crossOrigin = &quot;Anonymous&quot;;   cat.posx = x;   cat.posy = y;   cat.onload = function() {    var x = this.posx;    var y = this.posy;    g_mosaic_context.drawImage( this, x * g_dimensionTile , y * g_dimensionTile );     ++theresultsarein;    if( theresultsarein == 91 )    {         var daurl = g_mosaic_canvas.toDataURL( &quot;image/jpeg&quot;, 0.8 );     document.location = daurl;    }   }   cat.src = path;  } }}&lt;br&gt;Enter your google streetview URL here and click on submit&lt;BR&gt;&lt;input type=&quot;text&quot; size=128 id=&quot;panoid&quot; value=&quot;&quot;/&gt;&lt;button  href=&quot;[removed];&quot;&gt;Submit&lt;&lt;br&gt;&lt;canvas id = &#39;mosaic_canvas&#39; width = 6656 height = 3584&gt;
  • English BobEnglish Bob Posts: 113
    edited June 2015
    This may just be the best thing in the world, ever. :)
    I'm using Chrome in Windows 7, but the HTML5 version is giving me an error message rather than the final JPEG. Any ideas, or things I can do to help debug it?
    500 x 243 - 9K
    Post edited by English Bob on
    If you're worried about maintaining code formatting, perhaps it would be easier to link to the GitHub gist I created.
    &lt;!-- script src="https://gist.github.com/esemwy/75b9ef7fd042d4947745.js">&lt;!--/script>;
    I added the "!--" to the tags above to keep the forum software from eating it. It'll embed nicely formatted source and add a helpful link to the raw file.
  • DigiDotzDigiDotz Posts: 515
    I get as far as the mcjMontage.bat , double click to run within saved webpage directory, but get this (attached image)
    645 x 306 - 15K
    ... the HTML5 version is giving me an error message ...
    Further to that - and apologies for the multi-threaded thread - it works for me in Firefox, but I get a similar error message in Opera. In IE10, the image apparently downloads in full but it never goes to the final JPEG. I have a solution now, anyway: use Firefox.
  • KalisxKalisx Posts: 112
    Thank you so much for this great tool :-)
    Here is a quick render.
    StreetView in Cyberfox (Firefox x64) + mcjMosaicHTML5 + sketch filter in paint software + mcjSkySphere.
    1336 x 825 - 1M
    there's a security feature, i dont know if it's in html5 or in browsers
    but since mcjMosaicHTML5.html pulls images from google.com
    something or someone marks my mozaic as "tainted"
    and prevents the mozaic from being converted into a solid image
    that's why there's a line in mcjMosaicHTML5.html that reads
    cat.crossOrigin = "Anonymous";
    it's the first time i encountered this annoyance
    maybe maybe using Notepad, if you replace this line with
    cat.setAttribute('crossOrigin', 'anonymous');
    maybe it will work with other browsers
    also, in the Google-Chrome settings, maybe there's a setting to loosen the security concerning crossOrigin
    i saw it refered to as CORS also
    were the cbk cbk(1) cbk(2) files in the same folder as mcjMontage.bat?
    because mcjMondage.bat is basically ordering imagemagick to take the images from "right here where i, mcjMontage.bat am located"
    i updated the Esemwy_Version_2.py with that version
    i'll also see if i can link to yout github page since there may be future updates and documentation
