Daz to Maya bridge no longer works
![twalker_2eb94ee4](https://secure.gravatar.com/avatar/4947b4d7005da233f2d380a21d15ba30?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F4947b4d7005da233f2d380a21d15ba30_100.png)
An update came through Daz Central on June 9th for for the Daz to Maya bridge. After installing the update, the bridge no longer works. It appears my script settings and udpated Daz Studio are no longer connecting correctly. Not sure what the update was suppose to accomplish as the Maya bridge was working prior to this.
Yeah, I tried installing it through DIM and Daz Central, and it's not showing up in my scripts tab at the top. I hope someone can fix this.
Got it to show up in Daz, but can't figure out how to get it to show up in Maya. I tried the install plug-in option from the export menu and nothing seemed to work no matter where I saved it to.
Got it to work in Maya finally. I had to go grab the zip file from the github and then follow this tutorial around the five minute mark to know where to put the files (675) How To Fix DazToMaya 1.7 With Maya 2022 - YouTube Now it brings the character into Maya without a problem.
Sorry for the late reply. I will try to post a set of videos soon and will also link it to this thread.
I watched th video to which you linked above. If you are referring to timecode 6:18 where the files are installed into the "\Documents\maya\plug-ins" folder, then that will not work with the latest version of the DazToMaya Bridge 2022, since it is a technically a Maya module and not a plugin. What version of Maya are you using? Do you have your documents folder in a custom path?
When you use the install plugin button, it will give you feedback to exactly where it installed the files. Please post a screenshot of that image like the one below. That will help me figure out why the plugin installer is not working for you. Thanks!
EDIT:
I've released a new version which may help users who are unable to use the "Install Plugin" button due to custom Documents path or custom MAYA_APP_DIR setting:
https://github.com/daz3d/DazToMaya/releases
Please let me know if this fixes your issues. Thanks
its sux dosnt work at all ,that's why most program are abandoned because of that
