My model when imported it become original black male model.
I'm stuck at this step after export from daz to cinema4d , after I clicked to imported model from daz it only show original male model in black . I have try it several times to install and uninstall the plug in but it didn't work.
Before that I was worry because my daz studio don't have script to use ( daz to cinema4d bridge ) then I saw your very new post , I follow exactly the video but it still didn't work.
Hope you can help me with this. Thank you
1920 x 1080 - 440K
Please put the Daz Studio Viewport in Smooth Shaded Drawstyle before taking a screenshot of a nude figure.
Hi Kyle,
I posted a new bugfix that is not yet on Daz Central yet, so you will have to manually download and install it: https://github.com/daz3d/DazToC4D/releases/tag/2022.1.8
It should fix problems for people with custom Documents folders, as long as you are using Cinem4D R23 and above. (Currently working on adding support for older versions that use Python 2.)
My bad. Will do it next time , thank you to remind me.
Thank you so much for your help . I think I have try this with manually install ( throuhgt your tutorials on youtube ) but it still have them same problem when import from c4d. Is it possible if you can update full step by step from insallation daz studio to importing model in cinema4d , I have follow the step carefully and I have try multiple ways but it doesn't work .
I have try the new bug fix file , and following exactly the steps but I'm not sure why it's still not working. Please check theo video I posted. I try to upload video here but it take quite long so I upload in vimeo:
Thank you
