Where do I find freshly Made PCF
QuietrobQuietrob Posts: 361
edited December 1969 in Poser Discussion
PCF. Better known as Poser Companion Files.
I'm trying to make them for a prop. I supposedly did everything necessary to make the Poser Companion Files. I received no Error Messages or crashes.
But If DAZ 4.8 output them, I can't find them. I could use a hint as to where to look for them.
Thanks!
  • WandWWandW Posts: 2,846
    I still use 4.7, but the lower half of the dialogue is the destination path, so where did you put them? ;)
    I believe the default is whatever runtime folder you have selected/Runtime/Libraries/[Content Type]/DSON Conversions
  • QuietrobQuietrob Posts: 361
    As usual WandW is absolutely correct.
    I found the Poser CF's waiting right where you said they'd be.
    Using these I was able to get the Star Fury MK II (I wonder what happened to the Starfury MKI) up and flying. The poses work, I'm only missing some of the landing gear. That's okay. I always believed in magnetics for a smooth carrier based launch and landing. The weapons bay does lower and raise and missles launch.
    Thank you, WandW you are a total lifesaver!
    Here is the proof!
    1272 x 824 - 93K
