Where can I get Daz To Maya 1.7?
![polimorphick](https://secure.gravatar.com/avatar/e1c93185c9fe1af2c295851dfa067e08?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Fe1c93185c9fe1af2c295851dfa067e08_100.png)
I'm using Maya 2018. After updating the bridge, I'm having trouble importing a character. Where can I get version 1.7?
If it isn't on the plug-in's Github page I don't think you can.
The Github page has 1.6 and the new version. I didn't find any others.
I am working on adding in archive branches to github. For now, you can access the last DSA-based Maya bridge version here: https://github.com/daz3d/DazToMaya/tree/0c330faa183faa0f23e436d7d3c77e1bb917de66
I downloaded the version from the link. Uninstalled Daz2Maya in Daz Central. Copied two files(Daz to Maya.dsa DzMayaMorphSelectionDialog.dsa) to Daz Studio/appdir_common/scripts/support/DAZ/. Daz2Maya is missing from Daz3d. What am I doing wrong?
You need to create custom menu actions in Daz Studio for the script files. This was previously done by a "RunOnce" installer script which was packaged with the DIM package for DazToMaya-DSA. It's probably easiest for you to do it manually than to try to track down, install and run that script just to create a menu item.
Here's how to do it manually:
I am assuming that you installed the dsa files into the true parent folder containing your DAZStudio.exe and not literally "Daz Studio/appdir_common/scripts/support/DAZ/". Example, the correct path for my installation is: "C:\DAZ 3D\Applications\64-bit\DAZ 3D\DAZStudio4\scripts\support\DAZ"
Thanks for the instruction. Because I had to run the script from the explorer folder to export the character.
This version of the script works correctly. I think my problem is solved. Thank you!
Can someone just post the full 1.7 version here please?
