mac users and the new daz zips - it is dead easy and quick
esther
Use this utility to merge your runtimes wherever you want them.
You do NOT have to place your subfolders manually one by one despite what the pdf that daz gave us for installing their new zips says.
well you probably all know this already and have found a way, but in case you are new this is a really good way to merge your stuff eg two runtimes together:-
http://www.ilike.co.nz/SoftwareDev/dittoGUI.html
I'm pretty sure the latest OS for mac has an inbuilt merging method anyway, but I am still on snow leopard OS X.
DAZ - i think this should be added to your pdf please.
I use a fairly straightforward Applescript compiled into an application. Just drag and drop a folder, wait a few moments or minutes (depending on number and size of files) and it is copied into My Library.
(Derived in part from a sample script I found online and lost the link to long ago.)
This assumes that your My Library folder is in the default location. If it isn't, adjust the path in the script accordingly.
A "exited with non-zero status" error message may occur sometimes. This is a non-critical error, probably indicating a duplicate file somewhere. I have never had a product fail to work after this error.
After use, the original folder may be safely deleted.
and if there are already contents in my library, does it merge the two folders?
Because merging not copying is the thing I'm trying to tell everyone about.
Love esther
Yes, it merges. Drag and drop, and everything falls right into place in your existing folder without harming anything that's already there.
great.
well there is no reason for anyone to manually move all the subfolders hey.
Don't forget that this is only the first half of the system - there will also be an install manager that will take care of the merging for you, if you wish to use it.
I must have stopped reading the pdf too early. I stopped when it said to manually put all the subfolders into the correct runtime folder structure when you have decided where you want the files installed.
Love esther
That's awesome - thanks for posting!
That doesn't help at all until the install manager is actually released. It's been coming "soon" for how many months now?
And if you split your content so you have over a dozen *different* libraries, and want to install things specifically into only one of them?
As far as I know, from what has been said, the install manager will have options to pick the destination folder as the current installers do.
