Custom Prop (User Created) not moving with Poses?
EnoughButterEnoughButter Posts: 103
edited July 2022 in New Users
Hi,
I created a custom prop (a shirt nametag made in Blender and exported as OBJ then imported to DAZ) and parented it to my figure. If I Transform my figure (Translate, Rotate, Scale) the prop moves along with the controls.
But any custom pose just leaves it floating in the air. Is there a step I'm missing?
Post edited by EnoughButter on
  • TynkereTynkere Posts: 834
    No offense if you're already doing this.  Just to help clarify.  Parenting to prop to base actore or specific part of the actor?
    If parenting nametag to the base actor-- in scene tab (in scene pane it looks like 3 open beehive or hexagon shapes) prop would follow transforms on x,y, z but not poses.
    Parent nametag prop to specific area-- upper chest-- and prop should follow poses and moving figure around in the scene.
    If already doing that-- hmmm... a mystery.
  • EnoughButterEnoughButter Posts: 103
    edited July 2022
    Ah, thank you! I guess I should try to parent to the upper chest of the shirt (as opposed to the G8 figure).
    Edit: Ok, I guess I just have to parent it to the upper chest of the character-the shirt doesn't seem to work.Still needs to be manually adjusted.
    edited July 2022
    Glad it helped.  And yes-- depending on pose, will still need some tweaking.  At risk of sounding pedandic, here is way of making tweaks a bit easier.  Change "Nudge" to smaller value than default 1 or .5
    749 x 431 - 45K
    716 x 965 - 148K
    Post edited by Tynkere on
    Thanks! Definitely will help.
    So is there any way for me to add my prop to the shirt asset itself? So everyone who wears the shirt gets it automatically loaded in and parented/ adjusted? Do I need to re-save the shirt as a custom asset?
  • NorthOf45NorthOf45 Posts: 5,530
    You could make it a wearable preset, with the badge parented to the shirt (Save As -> Wearable(s) Preset). You might want to look into "Rigid Follow Nodes". Your prop will stay glued to a specific polygon or polygons no matter how the shirt moves.
    Rigid Follow Modes sounds perfect, thanks!
